Passcode Reset for Bluetooth
I go to the Update device list in COMAND and it goes through the scan, and no option ever comes up in COMAND to enter a new passcode nor does it show my new phone.... My phone, however, is prompted with a message that says "enter MB bluetooth passcode" - But I don't know what I made the passcode when I set up the original phone last fall.
I then tried the sytem reset through COMAND, which didn't work. I also tried disconnecting the battery, which didn't work. Is there any way to reset this code or is there a default one from the factory?
The phone is prompted by MB Bluetooth to enter the code, as soon as I enter any code into the phone, COMAND says invalid device or something. At no point does COMAND let me enter a password.
make sure to have the car in external authorization mode, then on your curve add new device, the curve should find the MBphonesystem, then prompt you to pair...after the prompt you should be able to enter the 4-digit code (whatever code you choose), then enter it again on the command and pairing should be complete.
the "62872" code should be used with the bluetooth puck only.
