navigation install upgrade
Old May 24, 2008 | 03:00 PM
gesvyn79's Avatar
c300
my c-class doesn't have a navigation, is it possible to add the navigation?
Old May 24, 2008 | 03:34 PM
joshieca's Avatar
'08 C350 Sport & '08 528i
Yeah I was wondering what sorta after-market options that be installed IN DASH on the 2008 C class's?
Old May 24, 2008 | 03:43 PM
tbenz's Avatar
ML320
you can't add navi it comes with the command not a option with the standard radio, don't know if you can get anything in the aftermarket world
Old May 24, 2008 | 04:38 PM
SUNILP's Avatar
2015 E250D
yes you can add a factory nav system on your w204 if it did NOT come with one.
Old May 24, 2008 | 05:01 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
I don't understand why you would do this after the fact? Its probably more expensive and more of a hassle. At this point I'd get a Garmin and call it a day. Aesthetically, i don't like the look of them but functionality is a ten.
Old May 24, 2008 | 05:10 PM
ManchesterMerc's Avatar
2008 220CDI Sport Auto Estate, Obsidian Black, Black leather, Heated Seats,Pan Roof, Comand,
See attached link, might be worth asking if possible and how much. But I must agree with AMG
http://www.mercupgrades.com/COMAND+A...rticle-23.html
Old May 24, 2008 | 05:53 PM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
most dealers would say no u can't its factory option only
If this were the case, I want someone to put in Sirius sat in my car!
Old May 24, 2008 | 07:23 PM
tbenz's Avatar
ML320
you must be miss informed, navigation comes with the command system,
if you have the audio 20 system the only way to add navigation is to have the command unit installed,on a w204 the navigation is on a hard drive the same as a s class it does not use a dvd disc
Old May 25, 2008 | 09:32 AM
The Mercster's Avatar
C320 CDI Elegance
I'd also say that for a fraction of the cost you'd pay for a retrofit, you can get a very decent hard-wire job done on a Garmin or whatever, which would look neat without any trailing wires.
Depending on the size of the GPS unit you get, I'm sure with some creative thinking, you may even be able to get it fixed under the sliding radio cover.
Old May 25, 2008 | 10:28 AM
SUNILP's Avatar
2015 E250D
No, I am not misinformed. I am aware the nav is on a hard drive.
http://web.mac.com/motorwerks
Old May 25, 2008 | 11:12 AM
There are 2 options for navigation 1 is Comand and 2 is APS 50 that uses the smaller screen. I don't know if APS 20 can be upgraded to APS 50 but see attached link for info on how it looks. Might be worth asking your MB dealer.
Hope this helps.
http://e-services.mercedes-benz.com/...lim/511_02.jpg
Old May 25, 2008 | 12:31 PM
angeloxnet's Avatar
Not sure what im looking for on that site, didn't see anything about W204 cars
Old May 25, 2008 | 01:29 PM
SUNILP's Avatar
2015 E250D
I don't have any w204 info on there yet but will shortly. Any 204 can be upgraded to navigation as it came from factory.
Old May 25, 2008 | 04:56 PM
Hey partner, check this out. If I didn't have Nav and didn't want to spend a fortune this looks like a good set up.
Old May 25, 2008 | 05:59 PM
C320 CDI Elegance
One further consideration against a retrofit. I know the Comand has a lot of advantages, but a portable GPS device (Garmin or whatever else), do come very close in terms of functionality. In some cases, I think they are even better. Eg, with the command, you cannot upload your personalised POIs, like speed camera locations. In my car, I've got the command + a portable GPS to alert me to those dammed speed cameras.
Old May 24, 2010 | 11:09 AM
chefjon204's Avatar
2009 C300 sport W204
Wink
hi i dont have a nav also and i am interested on your nice gps setup where did you buy the mount for the c300 i want one
Old Aug 11, 2013 | 01:55 PM
luis1353's Avatar
2011 MB c300 sport
Does anyone want to split the cost of the new upgrade available for the Navigation I have a 2011 C300
Old Aug 11, 2013 | 04:48 PM
Doa's Avatar
Doa
W205
with the NTG4.5 COMAND you CAN upload your own POI's!
Old Feb 27, 2015 | 11:43 PM
naughty1's Avatar
2008 c350
Can you help me on installation of navigation unit into c350
Old Mar 5, 2015 | 01:31 AM
centfl-c300spt's Avatar
2008 C-300
So I just replaced my Audio 20 head unit. Here's what I found out in the process.
First, you can put any option MB makes in your car; sirius, Navi, CD changer, etc. but you,ll have to have the dealer code the system to the car and that can get expensive. They can charge what ever they want.
Second, start looking around esp. LKQ site on Ebay. You'll see how expensive the parts for a retrofit can get. You want the pop-up screen right? You're gonna need the head unit as well. Don't forget any modules you don't have, ie sirius or backup cam. This can easily run to $1500 or more.
Don't forget the labor involved. You'll have to run new wires and take apart some of the dash and center console.
The used head unit from a GLK cost $225. The labor to put it in was $225 (had the shop put a new center vent in and an AMG leather shift knob while everything was taken apart.) Luckily the head unit was from the same year as mine and didn't need to be coded at the dealer. Any other year and it would have had to. I was informed it would be a $300 charge at the dealer.
IMO, I'd buy a Garmin and call it a day and pocket the rest. Get a tune or something else.
Old Mar 5, 2015 | 10:34 AM
Sincity's Avatar
https://mbworld.org/forums/c-class-w...radio-kit.html
