Wana throw on Boost
Sorry, I had 2
Either or (supercharger or turbo) will yield you anywhere from 25-55% more (crank) power, but it won't be cheap. Conservatively thinking, I would imagine a basic (4-6lbs of boost) supercharger setup to set you back upwards and over $4500-$5000. A more "race tuned" turbo setup (in example) will set you back $6-$7000. Those are just ball park figures from what I have personally experienced with various kits I have purchased and installed over the past few years. Installation will cost an additional $500-$1000+ depending on how complex and time consuming the kit is. For the most part, an average DIY mechanic can install a kit, BUT and I want to emphasize the word BUT, even a good DYI mechanic may not have the proper diagnostic and tuning tools (like a Dyno) to properly dial in the kit.
Is it worth it? Well, that all depends if you can budget the cost and are willing to accept the responsibilities that come with forced induction.
A: Increased maintenance and or service intervals (ie: engine oil, plugs and such)...
B: Increased drivetrain stress (transmission, rearend, etc)...
C: With the above statement, you will have NO warranty or recourse to take in the event you have a catastrophic mechanical failure...
D: Increased brake and tire wear...
If you can handle all of that, have the $$$, and drive responsibly enough on the streets - then by all means, forced induction will definitely give you a grin from ear to ear...
