Max size of CF card
Old Jun 6, 2008 | 10:41 AM
dragonii's Avatar
Mercedes S204 C320 CDI
Max size of CF card
Hi,
After reading a lot of posts here about the PCMCIA slot and its different connection options, I still couldn't find what would the maximum size of a CF card with a PCMCIA reader. There's talk about the different Types (I,II,III) and supposing that the COMMAND only accepts CF of type I and II, what would be the highest capacity CF one could use ?
Thanks.
Old Jul 9, 2008 | 08:58 AM
rebel_mtc's Avatar
1991 560SEL, 1981 300SD, 1983 300SD, 2008 C350
Are you sure that the command can not accept typeIII CF cards?
I really wish someone here will advice on the CF cards that can work. I'm tired of looking for another SDHC adapter as my first one which I waited for so long turns out to be uncompatible.
Old Jul 9, 2008 | 10:38 AM
Hazemonster's Avatar
2008 C300
I use a 16GB Compact Flash card without a problem. THIS one: http://www.newegg.com/Product/Produc...82E16820211170
Just remember not to have more than 255 FOLDERS, or some of your music will not show up in COMAND.
Old Jul 10, 2008 | 03:49 AM
rebel_mtc's Avatar
Thanks for the reply what is the adaptor that you use with this 16gb flash can you post it as well thanks.
By the way is this TYPE I or TYPE II?
Old Jul 11, 2008 | 10:49 AM
2008 C300
I don't really know if it is Type I or Type II...but it works! I use a CF to PCMCIA adapter I got a Fry's for $10. Any compact flash pcmcia adapter should work fine.
Good luck
Old Jul 12, 2008 | 08:12 AM
rebel_mtc's Avatar
Good luck
Can you post a photo of your CF card and it's adapter thanks.
