Missing Door Pin
Old Jun 8, 2008 | 09:31 PM
trial0r's Avatar
black c300 sport p1
Missing Door Pin
So I looked in my backseat the other day and I'm missing a door pin. Don't ask me how. Anyway...warranty or no?
Old Jun 8, 2008 | 09:36 PM
chilledbenz's Avatar
2008 R350 & 2008 C300
Depends on how well you know your service adviser, but honestly this item can't be more than a couple of dollars (cross your fingers, you never know with Benz).
Old Jun 9, 2008 | 02:00 AM
Lakerz4sho's Avatar
c300 sport
this has happened to a lot of people.. most likely it's the rear right pin, correct? mine ended up missing, and i have no idea when/how.
Old Jun 9, 2008 | 08:18 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
They are not a couple of dollars. I had mine fall off when someone sat in the rear seat and tried to unlock the door. Damn thing pulled right off. They are not like previous models (of course). The fronts come off but the rear is attached to the locking cable and is not made to be removable. It looks like a ball/socket but when the pin is removed- it cracks at the bottom and will no longer securely fit. It is covered under warranty (multiple complaints) but takes like 2 hrs to fix. I contacted CEC and tried to order the Brabus pins but the part number listed was for the w203. When I questioned them- they said Brabus made a mistake in their catalog and it would take 2 weeks from Germany. I really want a Euro vin for a C63 or C to order the flush mount pins.
Old Jun 9, 2008 | 02:14 PM
Wow, thanks for the info, thats just crazy! Leave it to Benz to make something as simple as a door lock pin cost you big bucks and lots of down time to fix. Good news is its covered under warranty and I really don't mind killing 2 hours in the show room while they fix my car.
Old Jun 9, 2008 | 03:32 PM
trial0r's Avatar
black c300 sport p1
do the brabus pins sit flush?
Old Jun 9, 2008 | 04:09 PM
E350 Sport/ML350RWD
Just verify the part # begins with 204... The catalog still shows 203 (which of course will not fit)
Old Jul 28, 2008 | 08:41 PM
mapate03's Avatar
c300
how to replace back door pin
does anybody know about how to replace back door pin cuz both rear pins are out.
Old Jul 28, 2008 | 08:49 PM
qlaval's Avatar
B200T 2007, C300 4MATIC 2009
It's a four hours job doing both so go to your dealership...
Old Jul 28, 2008 | 09:55 PM
E350 Sport/ML350RWD
Check this out
https://mbworld.org/forums/showpost....6&postcount=23
