Official Part Numbers Thread
Old Sep 25, 2019 | 07:55 PM
  #426
BlackBetty's Avatar
2011 C300
flex disc
What is the part number for the flex discs (coupler?) for a 2011 C300 Sport RWD?
Every online Mercedes parts dealer has the same problem with their software. Click on "propeller shaft" and it shows you the differential. So, no way to look up the part number.
Old Feb 18, 2020 | 10:08 PM
  #427
kjdeutin's Avatar
C63 AMG
Does anyone have the part number for the two T20 torx screws that hold the screen to the dash? I've searched these forums and elsewhere and cannot find the part number or a spare pair. If anyone knows where to find these, please let me know!
Old Oct 24, 2021 | 05:20 PM
  #428
hooch8's Avatar
2013 c300 4matic
I broke a gray plastic lock clip on the connector plug going to the ignition coil. Can someone help with how to go about replacing it, any parts #s?
BTW, anyone knows good link to download WIS?
Old Sep 12, 2022 | 12:40 AM
  #429
Kuro329's Avatar
W204
Hi anyone can help, this is W204 cup holder mat, who know this spare part numbers?
Old Oct 2, 2023 | 05:06 AM
  #430
Jon Stead's Avatar
W204 Wagn
HP AC pipe part number
Hi
i have a 2012 W204, Wagon, RHD, here in the U.K. I need a new HP AC pipe, the one from the condenser to the expansion valve.
I bought A2048304415 but it’s the wrong one.
the VIN is WDD2042022F822754. Does anybody know the correct part no. please?
Old Oct 2, 2023 | 06:12 AM
  #431
chipset's Avatar
c180
Originally Posted by Jon Stead
Hi
correct number for your vin is A204 830 49 16
Old Oct 2, 2023 | 06:14 AM
  #432
chipset's Avatar
c180
vin number please
Old Oct 2, 2023 | 08:02 AM
  #433
Jon Stead's Avatar
W204 Wagn
Thank you. Much appreciated.
Old Oct 18, 2023 | 12:22 PM
  #434
Jon Stead's Avatar
W204 Wagn
AC Compressor
Hi, I managed to get the required pipe with the invaluable help provided by chipset, but now I’m looking for the AC compressor. Do you know the part number for this part please?
The car is a 2012 W204, Wagon, RHD, here in the U.K. and the VIN is WDD2042022F822754.
Old Oct 18, 2023 | 01:58 PM
  #435
chipset's Avatar
c180
The last changing number of the AC compressor is A 000 830 27 00
Old Oct 18, 2023 | 02:04 PM
  #436
chipset's Avatar
c180
According to EPC, you should also purchase cable installation number A 270 150 57 20. If there is a problem with the installation with the existing installation, please purchase the installation I provided.
Old Jan 1, 2024 | 03:55 PM
  #437
boisy's Avatar
2013 C300
2013 W204 Front Driverside headlight "adaptive" bi xenon ballast part #
Hi Everyone,
I would really appreciate if someone can help me.
Trying to get the part number on 2013 C300 4matic Sport W204 Driver side adaptive headlight ballast #.
vin #: WDDGF8AB5DR268772
Thank you!!
Boisy
Old Jan 11, 2026 | 11:51 AM
  #438
Augster's Avatar
C250 Sport
I searched both this and the general forums but can't find it:
What are the part numbers of the oil drain plug and crush washer?
Old Jan 11, 2026 | 02:06 PM
  #439
Shimee's Avatar
2010 C350 Sport
Drain plug: A1119970330
Gasket: A007603014106
FYI the oil should be pumped out through the dipstick from M272 and M276 engines. It should only be drained from the drain plug when replacing the oil pan.
The reason is because the drain plug is painted over when the pan is painted with corrosion inhibiting paint. Removing the drain plug breaks the seal and can cause the pan to rust prematurely around the drain plug. This all depends on environmental conditions and some owners routinely drain oil this way without issue.
Use a knife to score the paint around the drain plug if removing it for the first time with the intention of reinstalling it.
Old Jan 11, 2026 | 03:10 PM
  #440
Augster's Avatar
C250 Sport
Thanks for the info!
I'm not the original owner and the car is 11 years old so who knows how the oil was drained over the years, but anyhow, I've done countless oil changes over decades and thought the W204 was no different. The two YouTube videos for DIY of the W204 showed them changing oil via the drain plug (not via oil extractor) so I went at it. It wasn't until I removed the plug that I noticed a copper crush washer. Whoops, too late to undo it.
I didn't notice any broken "sealant" around the plug, nor evidence of flaking coating, so it appears the plug had been removed in the past before I got to it.
Getting an oil extractor has been on my shopping list for eons now but this gave me an excuse to finally get one so I'll be ready for the next oil change.... which actually will be the traditional means since I have to remove the drain plug to install the new crush washer.
Old Jan 11, 2026 | 03:17 PM
  #441
Augster's Avatar
C250 Sport
Originally Posted by Shimee
Gasket: A6019970230
Hmm... Wherever I do a search of that PN, it comes up with Drain Plug, not the washer. Even on MB's own part's website...
Old Jan 11, 2026 | 03:23 PM
  #442
Shimee's Avatar
2010 C350 Sport
Woops I pasted an old part number for the drain plug instead of the gasket. Try A007603014106 instead. I believe the drain plug will come with a new gasket, but any old M14 copper crush washer should work.
Old Jan 11, 2026 | 03:54 PM
  #443
Augster's Avatar
C250 Sport
Yea, I noticed some images associated with drain plug PN shows a copper washer alongside it, but most don't. I believe if it's a genuine MB part, it'll come with a washer, whereas third-party plugs may or may not.
I have to ensure I get an OEM Mercedes-Benz part, otherwise I'll spend more to getting it separately...
Old May 8, 2026 | 09:03 PM
  #444
mpotok's Avatar
2012 C350 Coupe, 2011 E350 Convertible, 2019 GLE 43 AMG
Does anyone have code for this? how is this thing even called?
