AMSOIL..........
Old Jun 21, 2008 | 03:34 PM
myinternetsucks's Avatar
Merc C300 sport, arctic white, P1, MM/Navi, iPod kit, 20% Tint, C63 Grill, X-Pipe, HID DDM Kit
AMSOIL..........
has anyone used Amsoil products?
i was reading that they have a new line of filters with Nano-fiber Technology, meaning better filtration in both oil and air filters. Also they offer a cabin air filter too., so i plan on ordering these air filters instead of K&N, whats your take on Amsoil?
Old Jun 21, 2008 | 03:46 PM
ohlord's Avatar
Son't
use either.
Use OEM filters at autohausaz.com
flow better and work better.
are you changing your own oil?
ohlord
Old Jun 21, 2008 | 06:38 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Sporto?
If Amsoil is on the MB approved list of oils (which means they have tested it at Amsoil's expense) then go ahead. Isn't it more costly than Mobil 1?
Aside from that, I see your in your avatar that your C300 has a Sportomatic transmission. That would make it the only one in the universe since the Sportomatic was used in the Porsche 911 (and 914) from about 1968 through the mid '70s.
Old Jun 21, 2008 | 07:56 PM
no i meant has anyone used any thing from Amsoil, like filters they also make Wix filters too. here is the description on their new Nano-Tech filters.........
AMSOIL Ea Air Filters (EaA)
The Absolute Best Air Filtration Available for Cars and Light Trucks.
Guaranteed for 4 Years or 100,000 miles
AMSOIL Ea Air Filters represent a major breakthrough in filtration technology. The revolutionary nanofiber technology used in AMSOIL Ea Filters captures more dirt, holds more dirt and allows better air flow than conventional air filters. AMSOIL Ea Filters improve engine performance and help engines last longer.
Absolute Efficiency
AMSOIL Ea Air Filters are the most efficient filters available to the car/light truck market. Ea Air Filters’ synthetic nanofiber media removes 5 times more dust than traditional cellulose filter media alone and 50 times more dust than wet gauze filter media. AMSOIL Ea Air Filters have a service life of 100,000 miles or four years, whichever comes first.
Better Air Flow
AMSOIL Ea Air Filters allow more airflow than filters that use cellulose media alone. Cellulose fibers are larger than nanofibers, and have larger spaces between the fibers, causing contaminants to load in the depth of the media and plug the airflow path, which results in higher restriction and less capacity. The synthetic nanofibers in EaA Filter media have submicron diameters and small interfiber spaces, which result in more contaminants being captured on the surface of the media and lower restriction.
More Capacity
AMSOIL Ea Air Filters hold up to two and a half times more contaminants than cellulose air filters. Since the nanofibers in the media are so small there are more pores per square inch, allowing for higher dirt-holding capacity and lower pressure drop when compared to cellulose filter media alone. Thinner media fibers produce more uniform pore size distribution, improving the filter’s overall quality and ability to capture and retain particles. Testing shows that Ea Air Filters hold 15 times more contaminants than a wet gauze type filter.
Cleanable - Longer Life
When cleaned according to AMSOIL specifications and used in normal service, AMSOIL Ea Air Filters are guaranteed for 100,000 miles or four years, whichever comes first. EaA Filters remain effective for 25,000 miles or one year before requiring cleaning. This coincides with the AMSOIL 25,000-mile/one-year motor oil drain interval, adding even more convenience for motorists by consolidating routine maintenan
Old Jun 22, 2008 | 08:27 AM
Timeless's Avatar
2005 E55 ///AMG
I use AMSoil with OEM MB Filters. Service Advisor is even a dealer for AMSoil which I found out after bringing some in for an oil change.
