Who Runs Down Their Turbo ?
Old Jul 17, 2008 | 03:38 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I believe it is sensible to idle a turbo engine for a brief period instead of turning it off immediately after running at highway speeds or towing a heavy load. It at least gives the turbo a little time to run down with the bearing oil supply present & for the cooler exhaust gas to normalise the metal temperatures. I do not think it is necessary when idling around town at 60 Km unless you are accelerating like an 18 year old.
Old Jul 17, 2008 | 03:47 AM
Untertürkheim's Avatar
I always have on all my cars, especially the turbos, since I live at the top of the hill, they get a bit heated on the way home.
Old Jul 17, 2008 | 04:04 AM
cybertechc300's Avatar
W204
hey
i have turbo cars and i always set my turbo timer to 30 seconds after i run it hard or easy..always good to cool down the turbo and the motor.
Old Jul 17, 2008 | 08:35 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Always a good idea to let a turbo cool down after running it hard/spirited up to your destination. Shutting it off immediately could result in oil cooking on your turbo, leading it to it's death slowly.
Even when I'm easy on my car up to when I park, I give it 10 seconds to cool down. But if I've been in boost, I'll let it run for a minute (or longer, depending on how hard I ran it) before shutting her down.
Old Jul 18, 2008 | 10:47 AM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
Similar situation for SC engines? I can't say I always let a cool down period before shutting off...maybe I shoud....
Old Jul 18, 2008 | 11:22 AM
joebenz's Avatar
99 DC2, 08 C350
you should always let it cool down. i'd recommend a turbo timer if you dont want to sit in your car
Old Jul 18, 2008 | 12:33 PM
haha theres no way I'd put anything aftermarket like a turbo timer in my car. I'd rather sit and wait but I'm sure I wont
Old Jul 18, 2008 | 03:41 PM
joebenz's Avatar
99 DC2, 08 C350
i wasn't aiming that at you specifically :o
my response was a more general turbo response
in your case, superchargers generally don't have to be cooled. In most applications, the SC has its own oil supply.
Also, the internal bearings don't see nearly as much heat transferred through the intake manifold as a turbo will via the exhaust mani.
Old Jul 18, 2008 | 05:31 PM
trial0r's Avatar
black c300 sport p1
i used to let it cool after driving really hard but not for regular freeway driving or anything.
Old Jul 18, 2008 | 08:28 PM
451/443=EW's Avatar
C350 4Matic
Even on new cars? I know people said to cool down the turbo's yrs ago but I was under the impression that the new cars dont need it any more
Old Jul 18, 2008 | 08:38 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Turbos even on new cars today still need a cool down if driven hard up to your destination or long periods of time. If you run your car hard up to before you stop and it's a oil cooled turbo, by shutting it off immediately the oil will "coke" the turbo aka, "coking your turbo". The extreme high temps will cook that oil that's sitting there (since you've stopped the engine, no flow of oil to cool it down) and cause bearing failure.
By letting it run for a minute or few minutes, the oil cools down the turbo so that when you turn it off after that, the turbo is cool and won't cook the oil. Btw, there is a turbo cool down section in my owners manual.
Old Jul 21, 2008 | 08:15 AM
white_glass_top's Avatar
2008 C300 SPORT (white)
he is not talking about an aftermarket turbo, he has the european version of the car C200 CDI, it comes wit a factory turbo, Germans call (Kompressor)
