Removing A pillar
Old Jul 26, 2008 | 10:56 PM
peet's Avatar
09 C63
Removing A pillar
So before I totally snap whatever little tabs are in there which way does the A pillar cover go? into the center of the car or down or some combination of angles?
Anyone have a pic of what's on the inside of the pillar cover so I can self-determine?
Thanks!
Old Jul 28, 2008 | 04:48 PM
Rygar71's Avatar
C300
Assuming you're talking about the interior pillar that covers the seat belt mechanics. As I recall, the piller cover slides under the adjacent plastic on top so that requires a downward motion. There are 2 tabs on each side and you have to pull it outwards. You can locate the side tabs if you lift up on the foam like door trim. Start at the bottom and pull out. Once the side tabs detach pull down. Good luck.
Old Jul 28, 2008 | 06:13 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
That is the B pillar.
A is front
B is middle
C is rear
Old Jul 29, 2008 | 12:24 AM
peet's Avatar
09 C63
And thus - how does one get to the A pillar? I wrestled one loose - but am totally unsure as to how it attaches. That clip mechanism is odd. Anyone have stardiag diagrams?
Thanks!
