*DIY* I've Unleashed a Cyclops!
Palladium Silver C300 MM
JT
#33
2008 C-300/ 19' maya MRS black wheels H@R Springs//powerchipped//Brabus Trunk spoiler//HID Fogs//
Damn
That is way clean. Congrats man. Amazing
#34
2014 Ghibli S Q4 & 2008 C350
If we can get a group by going soon, I'll get in on it without hesitation.
#35
After feeding the wire under the passenger side sills through to the back, I proceeded to mount the camera. I had to cut a hole in the Handle Strip, right at the predetermined hole. The plastic's thick, so it was a PITA. I then fed the camera wires down the Trunk Lid and down towards the tail light.
-fin-
What tools did you use to cut the hole? And what did you use to seal it?
Excellent writeup; but thanks to this I will be out of a few hundred $$
Thanks!
#37
Fantastic writeup. I'm in for a GB as well. And to Rick - I hope that they can throw you a free V1 kit or something for lighting up the interest.
Amazing quality - though maybe a bit heavy on the water marks
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#39
'08 W204.081; M 272.948 KE30; Colour Code#792
I investigated to see if I could have placed the camera closer to the center of the Handle Strip, but the predetermined location was still the easiest and most logical to access. I guess MB had designed the Handle Strip to allow for a backup camera option.
I went el-cheapo and sealed up the inside with some silicone sealant. With the inner bracket and the tight space with which to mount your camera, I don't think there would be an appreciable amount water that could get into the space to cause a significant mess. I guess if you blasted it with your pressure hose... The camera itself is sealed and is weather resistant, so I'm not worried.
![Cheers](https://mbworld.org/forums/images/smilies/cheers.gif)
![](http://farm1.static.flickr.com/186/432171569_3488897598_o.jpg)
![action](https://mbworld.org/forums/images/smilies/action1.gif)
Thanks for the support! A V1 kit would be very nice... for my OTHER ride.
Haha that's a nice pic of Max & Miriya. Good resemblance to the original --->
![](https://upload.wikimedia.org/wikipedia/en/thumb/9/96/Max_lifting_Dana_onto_his_shoulder.gif/180px-Max_lifting_Dana_onto_his_shoulder.gif)
I was heavily into Animé in the late 80's & 90's, but have since moved away from it. No time to watch "cartoons" nowadays. I'm sure there's a lot of really good stuff I'm missing.
#40
In case anybody is wondering why the camera is mounted to a hole that's not in the center of the vehicle... it is because the predetermined location on the Handle Strip has an inner bracket that will hold your camera's mounting bracket. I neglected to take a picture from the inside to describe this better. Anyway, you can use your trusty Dremel (or drill) to take out the exterior plastic plate. Sand the edges as appropriate. Then mount your camera bracket inside.
Great job on the install by the way...
#44
Also, they sell a differnet verson of the VIM module that has an AUX input that accepts an external AV source. It costs a bit more. I am still trying to find out what kind of connector it will accept.
#46
Look great! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I have the same kit and I'm about the install it. Can I ask you a question about wiring? The camera has 3 wires, Black, Red, Purple. I was told that I should twist the Black + Purple and connect it to a GROUND point. The Red should be tapped into the REVERSE light. Is this correct?
#47
I just put in a call regarding a group buy. They're mulling it over and should be getting back with my later today or tomorrow. I'll post back when I hear from them.
#49
Krytech - I have an appt with them tomorrow to discuss as well. As I am in the Chicago area it may help move this along if I pop over. Anyhow, more info shortly.
#50
