*DIY* I've Unleashed a Cyclops!
Old Mar 7, 2011 | 03:52 PM
  #151
tunafish's Avatar
2008 C350
Wink
Originally Posted by Zulfiqar786
Newbie to the forum but want to thank everyone for this DIY and everyone's contribution. Was thinking about adding on the rearview camera, but also wanted to ask if having the factory ipod kit complicates it? Don't want any surprises going in. Has anyone done this setup who had the factory ipod kit, and if so, was it any different? Thanks.
No problem. I have a factory iPod unit and just added a backup camera.
Old Mar 7, 2011 | 05:35 PM
  #152
Zulfiqar786's Avatar
Thanks I_AM_JEFF and Tunafish.
From just reading all the threads on this topic it seemed that having the factory ipod unit made the install slightly more difficult. I called up MidCity today and they said that having the factory ipod meant you had to plug in everything a foot farther, but I didnt really understand what he meant. How exactly was the install different Tunafish?
One a side topic, the MidCity people were asking $37 for the Fakra to RCA connector (22 + 15 shipping). Is that what others were quoted and is there a reliable cheaper alternative (not making it urself)?! Thanks again.
Old Mar 8, 2011 | 11:39 AM
  #153
I am Jeff's Avatar
Steel Grey Metallic C63!!
You're welcome! The Fakra to RCA connector that Mid-City is of high quality and fits perfectly. That's my experience with their product. I had originally purchased a EBAY Fakra to RCA connector and it didn't fit as well. I paid a little less but that was a while back, so 37 dollars sounds reasonable.
Old Mar 26, 2011 | 01:40 PM
  #154
robmacca's Avatar
W204 C Class
How did you get the cable from the back of the camera from outside the trunk to inside? I cant see a hole that would take it other than maybe taking the registration light cover out which I dont really want to do... Can anyone help please?
Old Mar 26, 2011 | 04:50 PM
  #155
Ben'sBenz's Avatar
2009 C300 Luxury P1 w/Multimedia, Arctic White
robmacca, you have to drill a hole through that plastic strip that you remove and feed the wire through it.
Old Mar 26, 2011 | 06:11 PM
  #156
robmacca's Avatar
W204 C Class
I have drilled and filed the plastic strip but to get the cable from the outside of the car through the trunk to the inside is proving to be a pain, do you know what I mean? I am fitting the camera to the central position you see not the original that Mercedes intended so the right hand side as you look at the trunk.
Its dark here now anyway so I will have another shot tomorrow.
Old Apr 12, 2011 | 04:35 PM
  #157
mugennosora's Avatar
2018 C63s AMG and 2018 C43 AMG coupe
ahh man I really want to do this but i am scared to screw this up......anyone that did this around MA that can help me out?
Old Apr 12, 2011 | 05:43 PM
  #158
killerg's Avatar
99' Toyota Corolla
Or in NJ.
Old Apr 12, 2011 | 10:03 PM
  #159
Garry1104's Avatar
C300 4MATIC
I recently did mine last weekend. I basically ordered a FARKA cable from Mid-City ($22 + $10 shipping) and a Sony rear view camera from amazon. Followed the instructions from this DIY and mounted the OEM way. Didn't want to mount it in the middle b/c it would require taking out one of those plastic clips AND also it would be a pain to put the cable back into the trunk. The result came out fine and I got what I wanted. So special thanks goes to Rick Hunter and everyone on this forum for the help!
Old Apr 12, 2011 | 10:43 PM
  #160
killerg's Avatar
99' Toyota Corolla
come to hoboken and help me out gary!
Old Apr 12, 2011 | 11:51 PM
  #161
aww...no one near by boston ....
Old Apr 18, 2011 | 09:18 PM
  #162
tunafish's Avatar
2008 C350
Final comment on backup camera
I had an car stereo guy install a backup camera in my 2008 C350 (sorry, I forgot the camera brand) a month or so ago. It was a fair amount of work, and he charged me for 3 hrs labor (which seemed reasonable). I had changed the engineering menu to recognize the camera (thanks to this forum). The camera was powered from the backup lights. The only problem was that, when the car was cold, sometimes the video would not synch vertically. I could fix this by shifting out of Reverse and then back to Reverse, but this was a pain. I guessed the problem was a timing problem caused by using the backup lights to power the camera. I had the stereo guy change the wiring (no charge) to use a power source for the camera which was active when the ignition was on. This fixed the problem. The backup camera has been great. My thanks to this forum.
Old Apr 24, 2011 | 07:57 PM
  #163
bguybrad's Avatar
2015 c400 amg, 2007 ml350, 2008 c350 amg sports package - totaled
how much did the car stereo guy charge you? what was the total cost?
Old Apr 25, 2011 | 08:48 AM
  #164
tunafish's Avatar
2008 C350
3 hr labor @ $75/hr
camera $125
cables $25
tax $25
about $400 total
Old May 2, 2011 | 05:09 PM
  #165
tunafish's Avatar
2008 C350
Angry This is simply awful... BEWARE!
About a month after I installed a backup camera, my tire pressure monitor started failing intermittently. I took the car to the dealer and after working on it for a week, they decided the reason the tire pressure monitor did not work was the after market backup camera.
I think these guys are nuts!
Old May 2, 2011 | 05:26 PM
  #166
Cartronics's Avatar
Former Vendor of MBWorld
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
As a technician, that is the dumbest thing I have ever heard (unless it was powered from something in the rear of the car and not run to fuse aux power)
Old May 3, 2011 | 09:30 AM
  #167
Hey guys i bought a CCD camera from EBay, those really cheap ones (40 bucks), i'll let you guys know after i install it to see if it works, if it works just as well there is no reason to pay more lol
Old May 3, 2011 | 10:37 AM
  #168
capflam's Avatar
c400 4matic
How do you guys order directly from Midcity? I don't see anything on their site, don't they only provide lists of authorized dealers or something?
Does anyone know a a car stereo guy in south Florida that can do the install for me?
Old May 4, 2011 | 12:38 AM
  #169
Cartronics's Avatar
I don't think it is even possible to MAKE a CCD camera for $40 (we contract them in large quantities) and just the sensor alone is over $40 for a good quality one (let alone the support electronics).
I would think you are getting something used or actually CMOS that is intentionally mislabeled (we were just sent one for eval today that was a cmos labeled as ccd)
Old May 4, 2011 | 09:16 AM
  #170
thesleepydog's Avatar
2011 C250 VP1+AMG packs
Originally Posted by exdes
Get the FAKRA-RCA cable from Mid engineering. Theirs is easier to work with than the ones on ebay..
I used Pioneer ND-BC4 instead of the Kenwood.
That's all you need.
Try the NEW Kenwood CMOS-300... Has Multi angle features
Old May 4, 2011 | 10:10 AM
  #171
Cartronics's Avatar
We mean no disrespect, but look at some research online about CMOS cameras. They are TERRIBLE for automotive use. We have tested just about ever camera offered to us, and they simply do not last and are just plain bad. CCD cameras cost more for a reason, and are the only camera that should be used in an automotive application. There is a reason NOT ONE SINGLE CAR MANUFACTURER uses CMOS cameras in their cars when put in at the factory.
Old Jul 23, 2011 | 07:35 PM
  #172
paladiumonblack's Avatar
C300 4Matic with 18in AMG's
Need Help With Back Camera - SRVC, DRVM, DRVM-PSC
I have a late 2009 C300 with Command and Multi-Media and can not get the Engineering Menu to enable the backup camera. When i go into the menu and pick 7, 1.7, #18 is for the backup camera - I have 3 choices - non of them enable, The 3 choices are SRVC, DRVM, and DRVM-PSC. Which one do I choose. I tried all 3 and the last one (DRVM-PSC) worked one time and now it no longer does.
Also, can someone tell me if you need to separately turn on the AUX Video Input (Option 7.7.4) It was off, i have turned it on, but either way I still donut get the backup camera screen.
Anyone know what I should do and if it is possible....like I said, I got the screen one time but can't get it again.
Old Jul 23, 2011 | 08:32 PM
  #173
Restart required
Select one of the options, I thought it was the first one "SRVC", and then exit back to the main menu and then turn the car off, remove the keys and lock. After about 15-20 mins - go back to the car, unlock, start and move reverse gear - this should now work. The Command APS needs to restart after clearing the settings in its memory for the new option to take effect.
Hope this works for you.
Old Jul 23, 2011 | 10:22 PM
  #174
Smile
Thanks so much for the help....didn't know about removing the keys and waiting. It works perfectly now!
Old Jul 24, 2011 | 07:13 PM
  #175
My New Back-up Camera - Pioneer CCD ND-BC4
Alright so I finished the install of my Pioneer CCD camera ND-BC4. I went with CCD vs CMOS because the temp specs and reliability are much better with CCD. I got the camera on e-bay for $144.
I used the more centered location and mounted at least half the camera inside the trim. You can see from the last two pictures the camera is hardly visible at all. In the final position you it see a little of the trim at the top and bumper on the bottom (see shot of the screen). It works well for seeing the things you would way when backing up.
Also, I don't like tapping or splicing wires so I power my unit from the fuse bad in the trunk by using ad add a fuse (see pics)- also, I stuck the small power supply to the top of truck area behind the rear passenger seat using the velcro that came with the camera. Fun little project, nice addition to the C!
Attached Thumbnails *DIY* I've Unleashed a Cyclops!-img_1331.jpg   *DIY* I've Unleashed a Cyclops!-img_1332.jpg   *DIY* I've Unleashed a Cyclops!-img_1333.jpg   *DIY* I've Unleashed a Cyclops!-img_1334.jpg   *DIY* I've Unleashed a Cyclops!-img_1337.jpg
