X-pipe install pics
Old 08-14-2008, 11:34 AM
racetested's Avatar
08 MB
yxc145, can you weigh the resonator if you have a chance? I'm curious how much weight is saved. I'm just collecting data and researching for my overall goals of this car.
Old 08-14-2008, 12:31 PM
yxc145's Avatar
2004 E320, 2006 Audi A6, 2008 C350 W204, 2010 BMW F10, 2012 Porsche Carrera S 991, 2014 E350 W212
Racetested. it's actually pretty heavy. BASE on my years and years of weight lifting experience... i want to say it's about 25 to 30 lbs.
The x-pipe i got weighs about 10 lbs? so you save about 15 to 20 lbs there.
Old 08-14-2008, 02:36 PM
Saks_C350_Sport's Avatar
CLS63
Originally Posted by FrankW
I've already posted sound clips. different x-pipe however. mine's the magnaflow.
Frank can you post the part number for your MagnaFlow? Thank you in advance. Saks.
Old 08-14-2008, 03:00 PM
nbturbos's Avatar
2008 c300
Well I'm just speaking from my personal experience with a 300, the 350 might sound better than mine did with straight pipes. but IMO I think the X pipe will generally sound better in any car.
Originally Posted by got_thang?
I can't get my hands on any other camera besides my iPhone...
and listen to nbturbos don't get straight pipes he's totally correct I was totally ****ting about it not being raspy since i am a experiment for a muffler shop
Old 08-14-2008, 03:42 PM
MBworld Guru
FrankW's Avatar
white and whiter
not sure what is the part number, but they're called Magnaflow Tru-X pipes. here's a link I found from online. http://www.autoanything.com/exhausts...A2672A0A0.aspx
Old 08-14-2008, 06:27 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
that magnaflow looks very clean n well made
Old 08-14-2008, 07:15 PM
  #32
yxc145's Avatar
The reason MAGNAFLOW looks nice and clean is because it's not a pipe welded part. it's a Stamped part. how it is made is by stamping 2 flat plates in a shape of x, then weld the 2 plates together to form a "chamber" so you only see welding on the sides. There is no way a x pipe can look that "clean" if it was 2 or 4 pipes welded together.
I read in another x pipe thread (w211?) that these type of x pipe aren't really true X pipe, cause the "chamber" space doesn't create the scavenging effect. ok, don't ask me... i have no idea what that all means... I originally wanted to go with the Magnaflow one, but after reading that, i went and found something similar to the other type.
But i have to say... the magnaflow one sounds really good.
Old 08-14-2008, 07:37 PM
  #33
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
learn something new ever day
Old 08-14-2008, 08:18 PM
  #34
MBworld Guru
FrankW's Avatar
white and whiter
actually the inner is true x-pipe with smoother edge it only looks bulky outside. x-pipes with a narrow neck do more harm then good since you are basically choking the exhaust. personally I think they got the idea of going with bigger pipe i.e. loss of scavenging with the cross-piping confused
Old 08-14-2008, 11:21 PM
  #35
yxc145's Avatar
Frank
did you feel a little more kick, more power than before? cause I really feel it with mine now. people said because the OEM resonator is unrestrictive, there should be no increase in power/torque. but i really do feel something. I really wish someone can do a dyno test and find out.
Old 08-15-2008, 02:38 AM
  #36
MBworld Guru
FrankW's Avatar
white and whiter
Frank
the car pulls better at mid rpm after the x-pipe.
Old 08-15-2008, 04:03 AM
  #37
Petje's Avatar
W205 C400
Frank
Only Dyno will prove, but in my opinion the original resonator shall not be much restrictive, BUT it is more restrictive than the X pipes, because it's a resonator and resonators are always a bit restrictive.
With the X-pipes you have more free flow, so thats better, but with the straight pipe you will have a better result, because you have less backpressure.
I have this from a website of a Dutch exhaust firm:
A good sport exhaust has therefore no backpressure and satisfies to the following characteristics:
A sufficiently large dia meter pipe (also not too large).
Less sharp turnings.
Durable material.
  #38
MBworld Guru
FrankW's Avatar
white and whiter
OK fellows, I got the video from inside the car radio off and windows up for those that have asked how it sounds from inside the car. as I've described. it sounds stock inside the car other than when you are heavy on the throttle.
start the car, backing out of drive way, giving it some gas going up the hill. don't worry I've already warmed up the car. just wanted to show the sound from start to throttle.
http://www.youtube.com/watch?v=fVuxt3z_yX8
cruising at 70-75. picking up speed to 90. wind noise is louder than exhaust at cruising.
http://www.youtube.com/watch?v=qvu7pRA40OQ
Old 08-15-2008, 04:05 AM
  #39
MBworld Guru
FrankW's Avatar
white and whiter
Durable material.
resonators are restrictive mainly because they are designed to disrupt the exhaust flow and absorb the sound with those little holes. the x-pipe has no holes to disrupt the flow.
Old 08-15-2008, 07:48 AM
  #40
Petje's Avatar
W205 C400
True, but by the X-pipe the gasses from header 1 will meet the gasses from header 2 in the X, so it will disrupt a bit.... but that less than with the original resonator.
By the straight pipe the gasses will flow directly without a "meet and greet" in the X.
And only a dyno will prove which is better, the straight or the X pipe.
But both are better than the original i think...
Old 08-15-2008, 05:49 PM
  #41
MBworld Guru
FrankW's Avatar
white and whiter
actually in dual exhaust setup you want the x-pipe to equalize the flow down both side. If you take a look at the stock resonator's on the 204 it looks like XX from the inside. The straight pipe will not work as well as the x-pipe.
on many cars people have seen more gains from x-pipe than straight in dual exhaust setups.
Old 08-16-2008, 10:59 PM
  #42
CarGuru's Avatar
'08 C 300 Sport, '01 SL 500 & '08 Nissan Frontier SE Crew Cab 4WD
When you put the X-Pipe in do you remove the secondary or the twin cans up stream too or are those catalysts? No body has seemed to mention those or remove them. They seem to far down to be cats but what do I know?
-Ryan
Old 08-19-2008, 08:08 PM
  #43
speedye500's Avatar
W204 C300
Just put my x pipe on today. here are my pics
Attached Thumbnails X-pipe install pics-img00015.jpg   X-pipe install pics-img00016.jpg
Old 08-20-2008, 03:41 AM
  #44
MBworld Guru
FrankW's Avatar
white and whiter
-Ryan
no touching the cats needed. you only need to remove the resonator which is aft the secondary catalysts.
Old 08-20-2008, 12:02 PM
  #45
CarGuru's Avatar
Was it worth it.....
-Ryan
  #46
CarGuru's Avatar
Ok so there are four cats, just checking.
-Ryan
Old 08-20-2008, 10:53 PM
  #47
LapazC350's Avatar
2008 Mercedes C350
what option did u get
2.25,2.50, or 3.00
Old 08-20-2008, 11:06 PM
  #48
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
2.25,2.50, or 3.00
ya what size piping is the best? I heard too big, creates some kind of vaccum etc
Old 08-20-2008, 11:09 PM
  #49
yxc145's Avatar
I just noticed in the pictures of the MAGNAFLOW x pipe, they are much shorter than the actual OEM resonator. Looks like they have to weld extra pipes on both ends to be able to replace and fit in the space.
I personally think it's better to get something that is CLOSE FIT. The one I got from Mendral Bending Solution is almost the same size as the resonator (overall length: 18.5" and width: 4.5"). I would suggest getting that instead of the Magnaflow one. And it's cheaper.
There is also a member currently working on getting a custom perfect fit x pipe with MBS, you can try talking to them to get that part made the same way. maybe they will sell it cheaper now that they have made one.
Old 08-20-2008, 11:46 PM
  #50
angeloxnet's Avatar
I went to a local shop, and they said they will custom make one for me
Quick Reply: X-pipe install pics
