X-pipe install pics
#51
I also noticed some people weld 2 V shape pipes together instead of 4 small L shape pipes together.. i am not sure which one is better. but i think you should do some research 1st.
#54
i found this X-Pipe that has less welds from Summit Racing, which means better flow.
![](http://static.summitracing.com/global/images/prod/large/sum-642125_cp.jpg)
#55
hey i was wondering if somebody could explain to me if there's a difference in sound and/or performance between a true x-pipe made with pipes welded together and one made from stamped steel (such as the magnaflow one)
#56
'08 C350
actually in dual exhaust setup you want the x-pipe to equalize the flow down both side. If you take a look at the stock resonator's on the 204 it looks like XX from the inside. The straight pipe will not work as well as the x-pipe.
on many cars people have seen more gains from x-pipe than straight in dual exhaust setups.
#57
i think it doesnt matter, which type???? the shop that did mine, did 2 Y-PIPES with the weld in the in the center of course. sounds great, to me at least, been tryin to get a sound clip done, but the weather has been a lil bit poo pooish, lol. cant have benz online looking dirty, lol.
#58
C class w204 c180 cgi amg
Turbo
Hi how do i know if my turbo is working does the Mercedes c class w204 c180 cgi have a waste gate and where is the turbo lookubg from the front is it on the R or L side had my car for about 6 weeks can't hear the turbo i know i have one cause previous owner had 2 get a new one fitted £2 k
