Need help changing fog light bulbs
-Take off 3 torx 20 screws that are holding the cover on
-Twist the bulb
-Unplug the bulb
-Pry the bulb from the adaptor
-Swap the bulbs out
-Put back together
It's a little tricky to take out the bulb since it needs a little force and isn't much space, but hopes that helps
-Twist the bulb
-Unplug the bulb
-Swap the bulbs out
-Put back together
-Twist the bulb
-Unplug the bulb
-Swap the bulbs out
-Put back together
It's a little tricky to take out the bulb since it needs a little force and isn't much space, but hopes that helps![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
-Twist the bulb
-Unplug the bulb
-Swap the bulbs out
-Put back together
