Factory Spring Pad???
1. A 210 325 01 84 - 5mm Spring Pad
2. A 210 325 02 84 - 9mm Spring Pad
3. A 210 325 03 84 - 13mm Spring Pad
4. A 210 325 04 84 - 17mm Spring pad
-Totally a DIY project, (1) bolt removal "per side".
-Waiting on roof/trunk spoilers to arrive from GB, then I'll post pics.
Time to figure out which pads I have then. Another 10mm or so drop is perfect IMO. Thanks for the info.
2. #3 spring pads were replaced with #1 spring pads.
3. Don't know about the front, only worked on the rear.
4. Tools required:
-Torx bit#55 ($7 @ any auto parts store)
-Socket
-(2) jacks
- little elbow grease/time, SORRY!
This worked out great for what "I wanted".
Good luck with yours....
I have been on this board for a couple months and was dreaming of being able to drop the rear only about 1/2 inch but thought new springs/coilovers were my only options. An 8mm drop using all stock parts except for $20 worth of new spring pads is almost too good to be true. Can we get these from the dealer easily enough or should I just find them online? Will definitly be doing this one!!
