20's on my C
c300
20's on my C
I jus got 20" Giovanna rims installed yesterday, tell me what you think. I got 20x8.5 in the front with 245/30/20, and 20x10 in the rear with 255/30/20.
looks good, i like.... would have went 8.5 all the way around, leaves room to lower if u want later on, but wit ur 10s, they already stick out some, buts aight. ur car no one else has to drive it or make the payments, HOLLA!
19's, IMO, are too small. 20's are the way to go.
These rims, however, are definitely too wide. Makes the 20's look a lot bigger. I would have went 8.5/9.0 and lowered it slightly.
Anyhow, it still looks pretty good.
2008 Black Out C350 Saks Edition / 87 VW GTI
I like the wheels, but the rears rims look like they are sticking out that could be due to the tires are too small for those 20X10, do they rub on the fenders? Ask a couple of friends to take a test drive with you.
2008 CLK 350, 2005 Chrysler Crossfire Roadster
WoW! Can you even get your finger in that tight space?
Well, you know what I mean. Looks good though...
I hope the roads are nice where you are.
14' CLS550
those are very nice rims.. i have 20's on mine and there 225/30 and i had rubbing issues in the front fenders.. hit a couple bumps youll find out.. i would rather go with 19's and get a coil over kit and lower it the rite way.. springs are garbage
Good luck with those. I have a feeling you are going to be rubbing the rear fender when you hit speed bumps. I believe there were previous posts stating 10's were too wide for this car but it's all you.
With these configuration, I'm sure you'll have rubbing issue never think to lower it..
what's the offset btw? bigger than 45 shud be fine, but 10" is too big, max 9" wud be perfect in the back.
