Old 06-16-2015, 01:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension
Print Wikipost
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS
Old 03-08-2013, 12:49 PM
  #301
kevink2's Avatar
2004 Mazda6, 1993 RX7
You don't want to drop 'till the oil pan scrapes the ground, but these do look like good products for what you want to do. I think they serve the Austrailian racing sedans, and have grades of products based on how hard you race.
www.k-mac.com/mercedes
Also, you want tires with max rotation capacity, as edge wear will be hard to control. No directional, no asymetric (this side out on sidewall). You should try to reverse the direction of rotation when rotating the tires. If possible, plan to dismount and remount "reversed" on wheel at least one time if it can be done without damaging the tires.
Old 03-13-2013, 12:07 PM
  #302
SAMHATTI's Avatar
I am running on the HR sport springs now. I am due for some new tires for my 19 inch wheels. I am thinking of running a 235/40 19 (f) and 255/35 19 (r). Do you think I iwll have any issues?
Old 03-14-2013, 11:14 PM
  #303
portchop002's Avatar
08 C300 4Matic
Curious how much everyone paid to get the springs installed?
And any recommended shops in the CT / NY area
Old 03-15-2013, 02:21 AM
  #304
kevink2's Avatar
Originally Posted by deaner1979
I have 19" and on H & R SS on a 2008 c300 4matic....
H&R does not list SS spring for the 4MATIC, due to differences in spring positioning vs the RWD. Did you have any problems mounting them, and did they show anything unusual when loaded on the ground ... like excessive drop or lack of drop?
For the same reason, bilstein sells B8 shocks for drop springs on the RWD, but not the 4MATIC.
Old 03-18-2013, 06:53 PM
  #305
kevink2's Avatar
I have 19" and on H&R SS on a 2008 c300 4matic....
H&R offers sport springs for the 4MATIC's, and also for the RWD with different part numbers. But their engineers said that the SS springs are for rwd only, with only one part number. For some reason they did not bother making the special front coil needed for the 4MATIC (suspension altered for the front half shafts).
At least least 1 memeber has posted about doing what you did, and he found that the front spring was not stiff enough, and easily hit coil bind hard. This resulted in a nasty knock when the the front end or a front side was compressed from hard braking, etc.
Have you had any noises like this from the front?
Old 05-18-2013, 08:25 PM
  #306
macedo35's Avatar
c350 cdi
Front bumper lower centre section in Black
Hi were did you get that Front bumper lower centre section in Black?
I have a C350 CDI AMG Sport Plus 2013.
Carbon fibre is to expensive so just plain black is fine if i can find someone that makes them?
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-dsc_4022_1.jpg
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-dsc_4017_1.jpg
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-dsc_4042_1.jpg
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-dsc_4045_1.jpg
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-dsc_4050_1.jpg
Rim: OZ Ultraleggera
Front & Rear: 8x18 with a 45mm offset
Tire:
Front: 225/40/18
Rear: 235/40/18[/QUOTE]
Old 05-21-2013, 02:50 AM
  #307
bdog624's Avatar
C300 Sport
H&R SS
Here is my c300 w/H&R Super Sports, 5mm Pads, MBARTS Rear Camber Arms, Front OEM camber bolts.
Attached Thumbnails OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-hrc300.jpg
RamsesW204 (05-21-2020)
Old 06-28-2013, 04:07 PM
  #308
DoooDxitzxMeeH's Avatar
c300
H&R SS 19" rims
Here is a cross post of my setup on another thread:
https://mbworld.org/forums/c-class-w...ml#post5696182
Old 07-17-2013, 10:22 AM
  #309
nismosr's Avatar
2009 C300 Sport 4Matic
Originally Posted by xXHotelCrazyXx
Dropped on H&R SS with rear 5mm shim pads
20x8.5f +44 20x10r +55
hot !
Old 07-17-2013, 09:57 PM
  #310
Knightmare69's Avatar
2010 C200 CGI
Anyone on SuperSports running shorter endlinks in the front? If so, how much shorter than stock? I'm running adjustable ones which currently are about 2in shorter than stock but wondering if that's too short.
Old 07-18-2013, 12:42 AM
  #311
EuRo_C300's Avatar
2103 Cls550 | C300 MT For Sale
Pads
Want to lower with h&r super sports. I want even look. Which pads i have to get for the rear? 5mm or Stock? Thanks
Vossen CV3
Front 19X8.5 235/35/19
Rear 19X10 265/30/19
Old 09-01-2013, 08:02 AM
  #312
s2kq8's Avatar
c300 w204
Hello guys,
Heres my w204 with H&R Super sport.
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-null_zps5e658323.jpg
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-null_zps0a6cc55f.jpg
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-null_zpsaaa5322f.jpg
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-null_zpscd14ebbd.jpg
OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS-null_zps099d1c34.jpg
Sorry if the pics arent too clear took them from my phone and making a photoshoot soon with the w204 and my s2000.
Wheel specs are: 19x8 with 235/35 and rears are 19x9 with 265/30
Tony
Old 09-01-2013, 09:00 AM
  #313
Doa
Doa's Avatar
W205
i'm on a bilstein B14 PSS and its set about halfway so i'm 5cm lower then standard. i could go an other 2 to 3cm lower if wanted
Old 09-01-2013, 09:36 AM
  #314
nismosr's Avatar
Looks great what kind a rims are those?
Old 09-01-2013, 04:39 PM
  #315
s2kq8's Avatar
c300 w204
The new oem c63 wheels. Runs good.
Old 09-03-2013, 02:31 PM
  #316
slowc's Avatar
2010 c300 4matic , 2005 c230 kompressor (totaled) , 97' honda civic
what spring for 4matic? why wont the ss fit?
Old 09-03-2013, 08:42 PM
  #317
slowc's Avatar
Originally Posted by jmayn
This is just beautiful. Sold me on the H&R SS! DAMN!
How the front sit that low?
Old 11-05-2013, 10:37 AM
  #318
marko68's Avatar
W202 Esprit ; T-S204 PACK AMG
S204 ?? pic's ??
Old 11-05-2013, 10:48 AM
  #319
Makross's Avatar
2013 C250, 2T Ruckus
I am wondering the same thing.. but if you look closely our w204 rear wheel wells are larger than the front thats why it "looks" lower in the back but its even overall.
Old 11-17-2013, 07:23 PM
  #320
Richard2011's Avatar
2015 BMW M235i 6MT
H&R Super Sports are going to be my next mod, but I can't decide between stock spring pads or 5mm spring pads. I want an even gap on all four corners. I've heard accounts that with 5mm pads, the rear tire tucks a bit, but I can't really tell from the pictures I've seen.
Old 11-18-2013, 08:52 AM
  #321
marko68's Avatar
I rode Eibach pro kit, but rear seems high ... Is this normal?
p.s. Sorry my english
Old 11-19-2013, 12:40 PM
  #322
danfranjr's Avatar
W204
Hie Guys!
I am in dilemma in switching my current AMG sport package springs to HNR SS.
Current setup
F: 19x8 (if im not mistaken) with 235/35/19
R: 19x9.5 (if im not mistaken) with 265/30/19
Problem is when the road is uneven (like roller coaster) the rear tires tend to scratch the body even it is just me alone.
Any suggestion from dear all experienced MB owners?
A picture for some reference
Old 11-19-2013, 08:01 PM
  #323
EuRo_C300's Avatar
I'm running CV3's R 19X10 265/30/19 lowered on H&R Super sports, no issues. Are these the precision series ?
Old 11-20-2013, 10:24 AM
  #324
danfranjr's Avatar
W204
Euro:
Yeah it is the precision series. I bet the offset for the rear is not suitable.
I have just attached another pic with 19x9.5 (previous rims before RIP) I have no issue with heavy load.
Was wondering if I could adjust the rear camber (if any) so the upper tires will face in like "A" from the rear view together with HNR SS. Afraid il be wasting my time if it is still rubbing.
Old 01-15-2014, 09:50 PM
  #325
04boxster's Avatar
2014 C250, 2015 C63S E1
Originally Posted by Doanster
Part numbers for the sedans (well, my '09 anyway) below. Not sure if the coupes or face-lifted models are different or not.
A 210 325 01 84 - 5mm Spring Pad
A 210 325 02 84 - 9mm Spring Pad
A 210 325 03 84 - 13mm Spring Pad
A 210 325 04 84 - 17mm Spring pad
I'm doing the HR SS at the end of the month and I love the stance on that grey one. He mentioned he used 5mm pads on the rear. How can I maintain a clean subtle rake? The last thing I want is my car sitting lower in the rear by a noticeable margin. I've also heard that using 5mm front and rear can cause this. Any ideas?
Quick Reply: OFFICIAL W204 Lowering Spring Thread - Post Pics of Eibach Pro Kit, H&R Sport and SS
