rubbing sound
C350 4MATIC Premium Package Obsidian Black
rubbing sound
I have owned my c350 since April of 08. as of late i am noticing that when you turn the steering wheel all the way left or right at times there is a slight rubbing sound. anyone else notice this??
W212 2011 E-350 4Matic
if not it may be your tires.
I'd go have the dealer check.
or it may just be your turning the wheel too much
I don't have that problem.
yes stock 17's on the car. i should have been more descriptive with the sound. its more of screech that rub. very high pitch and it happens when i turn the wheel to the left to back into my stall at my place. i too thought that i was turning the wheel to much but the sound is only made when there is 2-3 inches left to turn the steering wheel. so this throws out the theory that i cranked the wheel all the way.
1 Post
C-300, XC70, Wrangler
Is this a slick/smooth garage floor? At slow speed? It could well be the tires slipping on the roadway.
It's unclear from your concern that it's a rubbing noise from the car body. Slow speed tight turns can cause the tire to slip on the roadway surface, and that generates noise. New tires on a very smooth surface can screech!
05-350slk and 08-c350
Also, I notice my wife told me the tire looks low when wheel turn, but when driving i notice nothing. It looks low because it's low profile tire. Am I corrected? I just took it itn for 1k mile checkup 2 weeks ago.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
nguyenmd350slk this is the exact noise i am speaking of it only happens at low speeds reversing. it does not matter if the car is on a regular road or under ground slick surface it still happens and its really starting to irritate me. i will keep you guys posted on the progress.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
