Replacement Door Lock Plungers...
Old Oct 2, 2008 | 09:54 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
I really don't care much for the little black plastic door lock plungers. They just seem to look and feel cheap. Has anyone seen oem or aftermarket replacements? Maybe a little shorter when locked and/or even a nice little MB Star would be pretty sweet.
Old Oct 2, 2008 | 10:02 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I really hate it when people answer a question by saying "try the search feature" because some might not even know it exists.
Try this: https://mbworld.org/forums/showthrea...door+pins+lock
aprince2die4's Avatar
08-C350 black/black
ebay..
Old Oct 2, 2008 | 10:16 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Many threads on this. Basically get a set of w203 aftermarket pins. The fronts just screw off and the new ones screw on. The backs though are a real PIA they must first be cut down then the threads have to be drilled out. I used neoprene hoseing to make a pressure fitting, others have followed a different path. My fronts sit flush but the backs are still about 1/4 inch out when locked. Good luck you will need it.
Old Oct 3, 2008 | 09:14 AM
C300Sport's Avatar
Thanks for the patience guys... If you search for "plungers" instead of "pins" you don't get much. Hopefully I will have some nice aluminum pins installed in a week or so.
