Old Jun 9, 2015, 01:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Cabin filter change
Old Mar 10, 2011 | 12:07 AM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
That filter
Originally Posted by brandno7
I just did this last night and it was a royal pain in the a$$. The three screws come off easily enough, but it's much easier to remove the entire bottom panel to get to the cabin air filter than to simply 'pull it down'. However, getting the bottom panel out is very tricky, disconnect the two light sources and then wrangle it out of there.. I purchased the cabin air filter below from parts geek, but it was slightly larger than the space allowed, which meant I have to smush it down to make it fit. Pain in the a$$ nonetheless.
http://www.partsgeek.com/catalog/200...ir_filter.html
It's hard to imagine why you had trouble getting the filter in since it only goes in one way. It's true that holding it in while sliding the retaining bracket is not easy.
Had you bought the MANN filter from Autohausaz.com, you would have paid $17.53. I paid $18.80 several months ago and now the price has dropped.
This supplier and their prices were mentioned in an earlier post.
Old Oct 15, 2011 | 01:36 AM
acr2001's Avatar
2012 C300 4Matic
Is the filter in the W204 downstream from the fan meaning it filters the air even when recirculate is turned on? That would be a very good upgrade from the flawed system in the W203 which allowed contaminants into the system when recirc was enabled.
Old Oct 15, 2011 | 06:11 AM
JimPap's Avatar
2008 C300 Sport, RWD, US
The filter is situated such that recirculation refilters the air.
Also be sure that you get the better quality filter as it has the carbon particals that'll take oders out of the air.
Old Oct 15, 2011 | 03:22 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
The filter out here is A$110 with 15% discount . Is there some where I can but it on line in the US?
Old Oct 15, 2011 | 10:17 PM
RLE's Avatar
RLE
You missed the two websites in post #26 of this thread?
Old Oct 16, 2011 | 02:27 AM
Carsy's Avatar
Thanks RLE. I can't believe the cost of postage from the USA ie US$61.63 , $75 for two which makes it better!! Adding windscreen inserts may make it worthwhile !!
Old Feb 10, 2012 | 10:03 AM
  #32
wszypszak's Avatar
2008 C300 4Matic Sportretired teacher/professor
I need some advice, please
Can anyone steer me to a illustrated DIY guide to change the combination (cabin) filter on my C300. I have seen the Mann photo, but it is blurry at best. Any suggestions would be appreciated.
Old Mar 19, 2012 | 05:45 PM
  #33
constantinkamal's Avatar
MB C180 CGI BE
A little DIY for the cabin filter replacement on a W204
Hope this video helps.
Old Mar 19, 2012 | 06:19 PM
  #34
wszypszak's Avatar
WOW! Really a super piece of info. Thank you so very much!!!
Old Mar 19, 2012 | 06:23 PM
  #35
MB C180 CGI BE
You're very welcome. I have been searching this awesome forum for some info on replacing my Air filter on a 2010 MB 180 Kompressor but haven't found anything yet but I'm still searching.
Old Apr 7, 2012 | 07:17 PM
  #36
trammm's Avatar
2009 C300 Sport
Can anyone tell me what the screw head is for opening the cabin air filter? Also if I'm not mistaken it's the same screw head used to open the air filters under the hood, yes?
Old Sep 11, 2012 | 02:58 AM
  #37
thomasclark952's Avatar
re:Cabin filter change
Cabin Crew Direct is a UK based course which helps you understand more about the role of cabin crew and how to become one. Get all the info about Cabin Crew Course, jobs and training.
Old Sep 11, 2012 | 04:13 AM
  #38
Diesel Benz's Avatar
I never knew I should attend a course to be able to be a cabin member on an MB. Sometimes a course could be useful to better understand other people in the cabin.
Old Apr 2, 2013 | 11:16 PM
  #39
Pete7874's Avatar
'08 C300 4Matic Sport, '02 530i
Just got done replacing it in mine. What a massive PITA! I've replaced cabin filters on a number of cars. This was by far the worst. Whoever designed it should be shot. I am never doing it again. I'd rather pay someone to do it.
Old Apr 3, 2013 | 07:33 AM
  #40
JimPap's Avatar
Originally Posted by Pete7874
Just got done replacing it in mine. What a massive PITA! I've replaced cabin filters on a number of cars. This was by far the worst. Whoever designed it should be shot. ...snip
Agreed. Can't imagine why they had to make it so hard unless it's to drive business to the dealership.
I'm due to replace mine again. Not looking forward to it.
Old Sep 14, 2013 | 07:05 AM
  #41
carmbu's Avatar
1998 CL600, 1998 C230 2010 C350
I came across a Filterheads.com Youtube video on how to replace the cabin air filter for the W204 C300.
Hope this helps.
Old Sep 14, 2013 | 08:37 AM
  #42
vic viper's Avatar
S213
Its hard to see in the video above but there is a fold in the right part of the glove box cover where the lower a-pillar cover is inserted, it is not easy to reinstall the cover and get it back right without first removing the a-pillar cover.
When we replace cabin filters on a B service we always dismantle the door trim and the lower a-pillar trim to get it right, that also makes it easier to remove the glove box cover.
Old Sep 15, 2013 | 04:07 PM
  #43
carmbu's Avatar
So I followed the procedure in the video for my 2010 C350 and was able to replace the cabin air filter and reinstall the glove box panel without the need to remove any trim pieces around the glovebox panel. It took a couple of minutes but it eventually went back into place. One observation on the video is that it did not mention the screw head type. I also noticed a posting on this thread asking about the screw heads on the panel. A Torx T20 size screwdriver worked for me to remove the 3 screws.
Old Sep 21, 2013 | 02:03 PM
  #44
trammm's Avatar
2009 C300 Sport
I finally figured it out, but thanks for posting anyway!
Old Apr 12, 2016 | 03:20 PM
  #45
cvx5832's Avatar
325Ci, 325Cic, C300
Old thread but seems to be the one that gets the most traffic. Here's what an 8 year old cabin filter looks like. I use the system primarily in recirc mode :
<img src="https://farm2.staticflickr.com/1644/25775975754_16a3a41d30_c.jpg" width="800" height="600" alt="image">
<img src="https://farm2.staticflickr.com/1656/25775979014_8cc285e97a_c.jpg" width="800" height="600" alt="image">
<img src="https://farm2.staticflickr.com/1501/26314604341_12c7566371_c.jpg" width="800" height="600" alt="image">
Old Apr 12, 2016 | 07:10 PM
  #46
edgalang's Avatar
Factory ordered 2012 MB C350 w/Dynamic Handling Package
Thanks for sharing, but let's hope you don't plan to advertise your car online anytime soon since this clearly indicates you do not follow the maintenance schedule.
Old Apr 12, 2016 | 07:40 PM
  #47
cvx5832's Avatar
325Ci, 325Cic, C300
Shame on me for sure!
Old Apr 13, 2016 | 10:00 PM
  #48
ghlkal's Avatar
2012 E550 v8-Biturbo
Thanks for posting this.
I guess I better think about changing mine ...
