DIY: Rear-View Camera under $200
Old 09-07-2010, 03:33 PM
  #101
Savage c-300's Avatar
C300 Sport, MM, P1
Originally Posted by miloc204
post pictyres of the camera installation i m ready to install kenwood cmos 200!
I followed the DYI on this thread and it works like a charm. I placed the wiring on the right passenger side instead so the cable is the grey and yellow one for the accessory and reverse tie in. It took me longer to do this project then most people here since I've never done anything like this before but for the most part it was fun and not to bad. I didn't take pictures of the install since it's mostly the same as what everyone else posted.
Make sure you have all the tools and parts gathered before you start. Also, make sure you have the right fakra cable. The one on ebay "Fakra E to RCA female" is not the exact cable but it will work. You'll need to shave it down a bit and the "RCA" female part isn't the one we need. You'll need to solder a real RCA female plug in it's place.
Old 09-08-2010, 01:04 AM
  #102
victort's Avatar
2010 C300
does this work on a w204 without the MM package??? i only have the UMI NAV+4
Old 09-08-2010, 02:12 AM
  #103
C300 Sport, MM, P1
you need the MM package with the big *** screen.
Old 09-08-2010, 12:15 PM
  #104
miloc204's Avatar
w204 amg
thanks.....i m ready to buy the cmos 200 from dynamicautosound
http://cgi.ebay.com/ebaymotors/ws/eB...0923&viewitem=
they told me that cmos 200 is NTSC but here in europe(i live in greece) we have PAL....so i buy it or not?my comand ntg4 would be able the NTSC convert to PAL?has the engineering mode this function?please help
Old 09-08-2010, 09:18 PM
  #105
victort's Avatar
2010 C300
are there different alternatives to get a back up camera with another kit? I saw on youtube that some guy installed one with the same screen that i have. anybody have any idea where i can get one?
here's a link
http://www.youtube.com/watch?v=OKomVpxnNl4
Old 09-11-2010, 12:36 PM
  #106
Former Vendor of MBWorld
E92-Lighting's Avatar
BBS LM's 18's + Kics
great installation guide
Old 09-26-2010, 04:26 AM
  #107
miloc204's Avatar
w204 amg
can we install the cmos 200 in our european comand ntg4 or not?has anybody in europe done this?
is problem with the ntsc video signal(usa) and pal(european)?
please you are my helppp
Old 09-26-2010, 11:56 AM
  #108
Nuru's Avatar
S350 BT 4MATIC
I seem to remember that you can change that setting, but I do not remember whether or not it requires one to change the region.
Old 10-04-2010, 08:41 AM
  #109
miloc204's Avatar
w204 amg
thanks Nuru........so i buy an ntsc or a pal video signal camera?
anyone guys from europe has installed rear-view camera to european ntg4 in order to help me?come on......
Old 10-23-2010, 12:10 AM
  #110
tbuix3's Avatar
c350
where did you guys mount your camera? rick hunter's way or vaderss's way?
Old 10-23-2010, 01:18 AM
  #111
hellasmania219's Avatar
2009 C300, 2012 GLK350, 2012 C350C
miloc204,
yiasou file, ellinas kai ego. eimai apo chalkida.
On your headunit, if you have the Comand, you can switch signal to NTSC for video (at least on most of the firmware?). This should allow the camera input to work. But you will probably no longer be able to play PAL DVDs.
I have never tried it myself but i have heard that it works...
Old 10-23-2010, 06:00 AM
  #112
miloc204's Avatar
w204 amg
Originally Posted by hellasmania219
miloc204,
efxaristo i bought the oem camera code 218 like vic viper in a very good price so i make the factory setting!
Old 10-29-2010, 12:06 PM
  #113
tbuix3's Avatar
c350
Old 10-29-2010, 02:23 PM
  #114
I am Jeff's Avatar
Steel Grey Metallic C63!!
I mounted it in the center location on my c350. I highly recommend that location due to the symmetry that it produces on your screen.
I can't begin to emphasize enough about how the OEM camera is a POS!! DO NOT BUY THE OEM CAMERA!! The quality is awful, when compared to the Kenwood camera.
Old 10-29-2010, 10:54 PM
  #115
tbuix3's Avatar
c350
so im assuming you had to cut the hole right?
Old 02-06-2011, 12:46 PM
  #116
until the end's Avatar
2009 c350 arctic White pano. MM HK
ok i want to know if i install all the parts do the camera work automatic when i engage the R or shold i hit the OK and arrow to work ???
and how if i want it to work auto. ????? do i need additional parts
Old 02-25-2011, 12:12 PM
  #117
icio67's Avatar
W204 C250 CGI Avantgarde AMG
Originally Posted by dacatz
just finish install the backup camera last week....all the instruction are
helpful...but i need to comment some more info because i have some area which i have trouble......Spec for my c63: APP (Canadian Version P30 w/lsd) Premium Package, Carbon Trim, Sat. radio, Keyless Go
1. My kenwood backup camera require Accessories wire (red) to hook up, and i spliced to a wire going to cig ligther fuse (Pink wire) (pics will provide later)
2. for the steering wheel control to activate the backup camera funtion for my Command system, it didn't work for me, therefore i access the engineering manual by pressing 1 , # and hang up key...then i goto menu 7.7.17 to turn the backup camera funtion on. But i don't know why there is 3 option to choose, so i try each one...none of them work,everytime when i put in reverse ,also even if i turn off the car and turn on right away, it still doesn't work. At last, I have figure it out!
To Turn on the backup camera function for the my kenwood camera, first go engineering menu 7.7.17 , then choose SRVC, next turn off the car, not sure if require to lock the door or not...but i locked the door....leave the car for 5 mins....then start the car, put in "R", the backup camera screen will be turn on.
Hello guys, I've followed all the instructions, step by step, but I never seen an image on the screen, it's remains black with "check entire surrounding!" I tried all three settings and waited for 5 minutes but nothing.
I tried the camera and it works, but no video on the Comand .....
I'm desperate, someone can give me some advice?
Thanks in advance
Old 02-25-2011, 01:15 PM
  #118
I am Jeff's Avatar
Did you check to make sure that you properly connected all the wires? How did you check to make sure the camera works? Via your laptop? I would make sure all the RCA and Fakra connectors are connected properly.
Old 02-26-2011, 01:39 AM
  #119
dacatz's Avatar
Location: Richmond Hill - Markham area, Toronto, Canada
c63, prius
sound like there is no power or loose connection to your backup camera....
Old 02-28-2011, 06:09 AM
  #120
icio67's Avatar
Hi, thanks for your reply....
Yes, I am sure that all cables are connected well.
I tested the camera by connecting a monitor instead of the Comand.
I tested the Fakra adapter.
I tried to switc from PAL to NTCS.
I also tried to update the Comand at the latest firmware version, it has made available new features... lines of size, features for hybrid vehicles, frequency on the Radio, clouds on the sky of the navi screen, etc.... but nothing...
Everything leads me to think that the Comand does not accept the video input ...
Old 02-28-2011, 02:43 PM
  #121
dacatz's Avatar
c63, prius
have u try press the sys in the command and enable the backup camera option in reservse?
Old 03-01-2011, 08:16 AM
  #122
2nd time im asking
Old 03-01-2011, 11:09 AM
  #123
tunafish's Avatar
2008 C350
Smile Whoopee! It works!
Local car stereo installer just hooked up a backup camera to my 2008 C350. I had previously followed the instructions elsewhere in the forum for informing COMAND that a backup camera was installed. I got a beautiful picture when I shifted into reverse. Except for getting the head unit out of the dash and running the cable, this is amazingly easy. No parts required other than a TV camera and the FAKRA connector. Zoowie!
Old 03-01-2011, 11:15 AM
  #124
icio67's Avatar
Sure... if I put in reverse I can see on the monitor the warning message and, if the option is enabled, the guide line green and red, but no image....
Old 03-01-2011, 11:37 AM
  #125
tunafish's Avatar
2008 C350
As soon as I enabled the backup camera option, but before the camera was installed, I saw the "check entire surroundings" warning, but not grid lines. The grid lines on my car are produced by the camera itself. Do you still see the grid lines if the camera is disconnected? This could be a clue as to your problem.
Quick Reply: DIY: Rear-View Camera under $200
