Debaged with a residual "shadow"
Old Oct 28, 2008 | 05:42 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
I debaged this weekend but can still see where the badge had been. It is really very light and can only be seen at certain angles. Is this from the UV non-exposure of the paint under the badge or maybe residual adhesive(even though it has been cleaned well)? It is no where near obvious enough to bother me but I was just curious as to the cause.
Old Oct 28, 2008 | 06:05 PM
cvkatigbak's Avatar
C300 MT, 350Z
go to kragen and buy some meguiars wax. got pics?
Old Oct 28, 2008 | 06:16 PM
PolePosition's Avatar
C350
Did you use Goo Gone to remove the residual adhesive? If not try that and then apply some wax. That should do it
Old Oct 28, 2008 | 06:32 PM
C300Sport's Avatar
I used Goo Gone and gave it a good coat of Maguires but there is still a very, very faint shadow. It really seems to the color of the silver under the clear coat. Anyhow, it is very hard to see so I am not too worried. If it is UV aging, it is soo slight that it should even out and be impossible to see soon.
Old Oct 28, 2008 | 09:22 PM
Pristine's Avatar
2014 E350 4Matic
I would suggest you leave it as is. The color will probably even out over time.
Old Nov 6, 2008 | 01:34 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Clay bar it !
Old Nov 7, 2008 | 11:44 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I have used the 3M scratch and swirl remover in the past. It works great. 3M also makes an Adhesive/Wax remover. You would definitely have to re-apply wax afterwards.
Old Nov 7, 2008 | 11:56 AM
webada's Avatar
528i, GLK
ditto, the mroe u stare at it the more apparent it is.... after couple of car washes and waxing, it will disappear.
Old Nov 7, 2008 | 03:25 PM
C300Sport's Avatar
I have washed and waxed it since the debadge and the last time I looked, couldn't notice a thing...
Old Nov 9, 2008 | 12:05 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I would be grateful to know why you would remove all your MB badges.Security?
Old Nov 9, 2008 | 03:18 AM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Looks
Old Nov 9, 2008 | 04:31 AM
Carsy's Avatar
Originally Posted by Azn_C300
Looks
Wow ! Thank you.
Old Nov 9, 2008 | 05:57 AM
CynCarvin32's Avatar
Mercedes Benz
Use some sort of solvent to remove any adhesive residue. If that does not work you will likely need some polishing with a buffing device of sorts. Depending on how bad the shadow is you could even need to have the area lightly color sanded.
Waiting will not cure this.
Use a porter cable or felx polisher with some moderately aggressive menzerna polishes and it should look like new. While you have all that out do the whole car!
Old Nov 9, 2008 | 07:41 AM
C300Sport's Avatar
It really is all about looks...I like the cleaner, more symmetrical look with the Benz logo in the middle and nothing on either side.
