W204 Door Pins
Old Nov 17, 2008 | 02:25 PM
nukefixer's Avatar
2012 US Edition C300 Luxury 4-Matic
W204 Door Pins
Whats up with the mention of dorr pins on some posts whereby the lisiting of modifications is shown?
Why change door pins?
I assume this is something to do with the door hinge pins, do they go bad?
nukefixer
Old Nov 17, 2008 | 03:06 PM
webada's Avatar
528i, GLK
cause they are cheap plastic and protrude out of the side panel, if you drive an automatic, you can't even put ur left (or right, if you drive on the other side) arm on the door comfortably.
Old Nov 17, 2008 | 03:13 PM
jstaneff's Avatar
C-300, XC70, Wrangler
Maybe a bit of explanation is in order.
"Door pin" is not intended to be confused with the hinge pins that hold the door onto the body. A Door Pin is the plastic thingy that sticks up allowing you to pull up higher to unlock the door.
Especially in the rear, they tend to simply break off on first/second pull. A fix has been developed for that.
For the front seats, they are uncomfortable when you rest your arm on the open window sill. They are poorly designed, and have bad effect when you do drive-in banking, drive-in food, etc.
Many other manufacturers have better approaches. The Mercedes door pin is a throw back to the 60s, but not as well done.
Helps?
Old Nov 17, 2008 | 04:57 PM
joshg1001's Avatar
2017 E300
^^ that and because they are hideous.
Old Nov 17, 2008 | 05:01 PM
webada's Avatar
528i, GLK
I miss the double pump on my bimmer.
Old Nov 17, 2008 | 08:38 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
I just heard that Brabus has corrected pins for the 204. The current listed pins they had associated with 204s were actually for 203s and were part marked as such. It's pressure held in the rear. Only problem....they're F'ing expensive.
Old Nov 17, 2008 | 11:52 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
how much and where (link) AZN?
they cant be more than 200 bucks right?
If they come in a 4 pack, ill split em with you... cus i LOVE my carbon fiber ones on the rear...
Old Nov 18, 2008 | 12:13 AM
Azn_C300's Avatar
Got that info from a shop near me. The owner also drives a 204 and has the new Brabus pins. Unfortunately, you won't be able to split as there's a front set and a rear set. They both sit flush.
Old Nov 18, 2008 | 01:58 AM
dalazernet's Avatar
2020 GLC300 4MATIC
They sit flush AND they replace our pins.... I'm almost 100% onboard at almost any cost. I just wish they slightly resembled the old golf tees -- these pins suck, I'll say it how it is. If your gonna make cheap crappy pins, at least get rid of the mold marks where they were broken out of the plastic mold. Ugh....
Old Nov 18, 2008 | 08:25 AM
C300SportFahrer's Avatar
C300 Sport
Talked with Mercedes here in Germany today. They can get the Brabus set consisting of 4 pieces 2 front, 2 rear for 80 Euro without Tax about 100-110 dollars factoring in exchange rate. If some people are interested I may be able to work a deal and get a few sets and get them cheaper than 80 a set. Shipping would be pretty decent too as it would only be a padded envelope for a few dollars.
let me know if anyone would be interested as I plan to order my set and could easily order more.
Shawn
Old Nov 18, 2008 | 12:30 PM
Azn_C300's Avatar
they sell for about $125 here in the US. Installation will probably run you $30-50. Have to remove door panel in the rear from what I understand.
I've attached the old Brabus part#/price list for 204s. As you can see in the part#, they mistakenly placed 203 pins for the 204s.
Old Nov 18, 2008 | 03:29 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
This is the Old catalog. It sounds like they have developed the pins for the rear. Copy-cats.
Old Nov 18, 2008 | 06:59 PM
Azn_C300's Avatar
yeah, I stated this was the old list to show that they were sending out 203 pins before. There are new ones for 204s now apparently.
Old Nov 19, 2008 | 09:44 PM
nukefixer's Avatar
Many thanks for the explanation!
Old Nov 19, 2008 | 09:54 PM
E350 Sport/ML350RWD
Do you have the new part#?
Old Feb 12, 2009 | 03:32 PM
thatonealex's Avatar
C220 CDI W204
Could anyone get a picture of the originals with the dimensions. I could try to machine some nice ones if theyre simple enough.
Old Feb 13, 2009 | 06:28 AM
Petje's Avatar
W205 C400
204-819-00
according to the Brabus website
Old Feb 13, 2009 | 02:22 PM
hemptation88's Avatar
2009 c300 4matic
anywhere to get carbon fiber ones?
Old Feb 13, 2009 | 03:16 PM
aprince2die4's Avatar
08-C350 black/black
ebay search "door pins"
Old Feb 13, 2009 | 04:07 PM
Azn_C300's Avatar
look for w203 ones
Old Feb 13, 2009 | 10:21 PM
2009 c300 4matic
is there a diy thread on here??
Old Jun 3, 2009 | 04:51 AM
justthinking's Avatar
2008 C300 Sport, 2010 RX350 AWD
Anyone got updated info regarding Brabus door pins??
Old Jun 3, 2009 | 12:20 PM
Azn_C300's Avatar
you'll have the same issue with Brabus pins as you will any other pin. Screw on fronts are just fine, but the rears will require custom work.
Old Jun 3, 2009 | 12:45 PM
TB5...'s Avatar
2009 C300 4Matic
is it possible to DIY on the back doors?
Old Jun 4, 2009 | 02:23 PM
aowhaus's Avatar
2008 C300 Sport 4matic
I'm thinking of removing the rear door pins and filling the hole with a black plastic cap or plug. That would be really clean looking.
Personally I think door pins are uneccessary when you have power door locks, and I never have people in the back seats.
