Brake Pads!
You cannot wash the rust away, you can only use your brakes and it goes away. This is all normal by the way.
Sure it looks nice but less mass on those discs means quickers fading
Will be replacing mine with "regular" discs. Don't like the cracks and the holes filling up
If washing the car can cause the brakes to look like rust, then our wet roads must do it too? Is MB hiding a "defect" when they put the brakes on slightly whenever the wipers are running? Hmm .... conspiracy lurks everywhere!
And I have drum brakes and no ABS on the Partner. It's murderous
I thought it was standard on most performance oriented cars? Happy it dries the brakes but unhappy that it will give extra wear.
Perhaps you had better send off an urgent message to every performance and supercar manufacturer on the planet that all the money they spend on braking systems to keep up with their products' performance is wasted.
Just sign it "A guy from Belgium who drives a fleet of pokey diesels, some of which he thinks are performance cars." They'll send somebody over.
Efficiency of either should depend upon the application.
ie Performance Driving where a lot of heat is generated Vs Normal sedate driving.
A solid disc contains more mass, therefore it will take longer for that larger mass to warm up (m*Q in thermodynamics).
A drilled disc will cool down faster and get rid of the dust more efficiently.
So, for us "normal people", a solid disc would be better and cause less problems on the road. A grooved rotor is a better option imo, lots of mass and gets the dust away efficiently.
Offcourse, drilled discs on AMGs, Porsches and Ferraris are the best choice when on track. But 90% of normal people never get on a track with their car.
And it's idiotic of MB to fit drilled discs to any C with AMG pack on it. Sure it looks good but it doesn't improve anything other than aesthetics...
And FYI, that "pokey diesel X5" wipes the floor with a BMW Z4. Remap ftw 285bhp!
Since you can only see the edge of a pad, you must be talking about the disc's. And yes ALL cars start to do this after a few days in rain, snow or car wash. Dont worry, it is very normal and your car is fine. If you let a car sit for years, it is also common to find your calipers are stuck. Like someone said just a few pumps of the brakes will remove the rust.
Mixing metals is always tricky, particularly with these two properties. On one end you have a "pretty" rotor that looks fabulous but wears easy, and an "ugly" rotor that stands up to wear and abuse. I'm glad most major companies have chosen function over form, as evidenced by the rust that we all see.
Regards,
Paolo
Although few C Class drivers will ever push their cars hard enough to benefit from the faster cooling of drilled rotors, all of us benefit everyday from the reduced mass of the rotors. This equates to less rotational inertia which improves both acceleration and braking. It is not a large difference but helpful none the less. Kinda ironic that hese big giant brake kits actually slow your car down in more ways than you want...
BTW, nobody produces drilled discs, to be perfectly accurate. Those holes are all cast in which reduces cracking.
But you can't argue with it's handling. Let's just shut up about the drivers
And the weightloss for those drilled discs (yes, I know it's cast or they'd crack even faster) is zero to nothing. You people are Americans remember, compare it to the extra weight of your body, other rims or even just seat heating or a glass roof...
It's a gimmick.
It's a gimmick.
You seem upset because RLE makes a comment about posers driving Z4s, but then come back and basically call all "Americanos" fat, performance posers and spoiled with every option...that's hilarious.
Drilled rotors are better for performance, period. How much better is certainly up for debate but that is the case for a great deal of the mild perfomrance mods.
I would say more but my dozen Crispy Cream doughnuts just arrived for breakfast...
