Finally Checked my tire pressure, what a surprise
I have had my car for about 5 months and realized I had gotten really lazy and not checked my tire pressures....TPMS made me kinda lazy I guess. To my surprise, my fronts were 37 psi and my rears were 39 and 40 psi. I know I should have checked them long, long ago but I was amazed MB had put so much air in them. I changed them back to 35 front and 30 rear (33 and 28 recommend) and the car rides much, much smoother. Guess that is what I get for being lazy. I will keep an eye on the MPG and see if it makes a noticeable difference.
My bad, the recommend is 28 Front and 33 Rear for the 225/45 17 fronts and 245/40 17 rears.
MB ships cars with very high air pressure so that the tires don't flat spot in transit. Its up to the dealer to bring them down to the correct pressure before delivery.
Mine were taken stone cold. I am guessing it may be like norb said..transit pressure to keep the tires from flat spotting.
2013 ML63 AMG PP
09' E350 AMG Sport, 09' C300, 03' Honda S2K
Is 33/ 38 the recomendation for the 18"s AMG rims, I dont really feel comfortable running 39 all around with my C63 rims as the AMG is alot heavier in the front. I am still wondering if it running 28/33 will be too low for 18'.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
mine are 225/45/R17 on all four wheels.
the recommended pressures according to the sticker is 29fr and 33rr for speeds upto 210kmph with 3 people inside. currently the pressure is set at 30 in all four.
would you think switching to the recommended pressure or going low/high will make the ride even more smoother ?
considering the roads are rough and uneven here in India
2008 C300 Sport, RWD, US
wishlist,
I made a somewhat lengthy post in another thread about tire presusre.
The first question has to be how many people do you normally ride around with? If you're full load, then use the recommended tire pressure. If it is like myself which is essentially 1 person almost 100% of the time, then go with 27 in front and 31 in rear. Now this is on a 2008 C300 sport (early production) that would tend to loosen your teeth when you hit a bump. Huge difference. The key, regardless of what anyone tells you is to watch your tire wear pattern. If it looks like the tires are wearing more from the centers than the sides, then you know you're over inflated. Conversely, if they're wearing more from the outsides than the center, you're under inflated.
In my case, my car runs quieter and softer than before. My only regret is that it took more over 2 years and 46,000 miles to figure it out.
14' CLS550
Don't sidewalls typically say the maximum tire pressure which isn't what you normally would run.
Contact the tire manufacturer. They could be helpful. Then post here what you find out.
14' CLS550
2016 C63, 2009 C3004M
Never trust the dealer. I did when I took delivery and ended up driving on 40+ all round for 3 months until one of them got punctured.
I've been trying to keep at about 31/36 since. It says 28/33 on the pillar but 30/35 on the gas cover but both agree on the +5 for higher speed/load. Knowing that the speed vs. pressure is a rising curve so based on how fast I could go realistically, I decided that +2 or +3 should be the sweet spot.
Some people underestimate the importance and the degree of impact tire pressure has on ride quality among other things. Afterall, tires are/should be the only contact points to the road which is the main source of effects you're ever going to feel while sitting inside the cabin. For the same reason, I believe that manufacturer's recommended tire pressure levels should be followed for all allowable wheel/tire sizes to maintain the relativity of the body to the road and ride comfort.
Something extra: when I switched to winter tires back in October, I went with nitrogen (because after they messed up my order and the nice manager decided to waive $250 off plus some extra stuff). They did 36 all round at the shop and I had lowered it to 31/35. Relying on TPMS for the most part, I finally measured it last week, and guess what, they're at 31/35 after 4 months of harsh Canadian winter driving! It's almost set 'n' forget! I'm not trying to start the whole 4/5 of the air is nitrogen stuff, but just something from my experience.
Here's a pretty good website that IMO tells the true story about running nitrogen in your tires.
http://home.comcast.net/~prestondrak..._tires_FAQ.htm
