Cluster ISSUE with C350
Old Feb 3, 2009 | 02:25 PM
DAnton1316's Avatar
2008 C350 Sports Sedan
Unhappy Cluster ISSUE with C350
I have had my C350 for a little over 6months and other than a cracked windshield, I have had not issues until now.
About 2 weeks ago a portion of my cluster display has begun to disappear and come back every few times I drive the car. Everything still works but it is very annoying. At the same time my mirrors folding in on lock are hit or miss as well.
I came here to see if anyone has heard of this issue and can help me out.
Kind Regards
Dan
Old Feb 3, 2009 | 02:41 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Warranty
Old Feb 3, 2009 | 02:48 PM
DAnton1316's Avatar
Originally Posted by tanktube67
Warranty
I have already talked to the dealer. They have no idea what the issue is and say I could be out of my car for a least a week. I came here hoping it was an easy fix and could avoid that.
I will most likely Warranty this.
- Dan
Old Feb 3, 2009 | 02:51 PM
tanktube67's Avatar
I think your dealer will give you a loaner??
Old Feb 3, 2009 | 02:53 PM
tanktube67's Avatar
Have them order the part, swap the LCD screen it wont take a lot of time.
Old Feb 3, 2009 | 03:04 PM
Diesel Benz's Avatar
I don't think they would have the LCD as a spare part but that would be the dealer's head ache. This one does seem odd though, it looks more like the computer did not print all the screen content for the second photo, or does it look different when you see it in real?
Usually when you have issues with an LCD it concerns full vertical or horizontal pixel lines. In this case it could be horizontal but it would concern at least two different positions which sounds a bit odd. I guess still possible.
Old Feb 3, 2009 | 03:10 PM
DAnton1316's Avatar
This is the problem...
The screen itself is fine. The dealership does not know where to start looking.
When acting up... All the trasmission information and the line disappear consistantly.
- Dan
Old Feb 3, 2009 | 04:00 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Does the transmission have a seperate control unit? Maybe it is not sending the info or there is a break in the line? Does it affect driveabiltiy?
Old Feb 3, 2009 | 04:40 PM
delirium's Avatar
C350
i had the same issue. it hasent happened for awhile now tho. I took it to the dealer & they could not get it to happen of course....
Old Feb 3, 2009 | 04:51 PM
MBTex's Avatar
2008 C350
The dealer should give you a loaner while they find out what the problem is, then they give you the car back while they order any parts they made need and give you a loaner again while they fix it.
That is an odd issue that I haven't heard of and could be caused by many things. Unless there is a bulletin on it (or if the dealer has seen the problem before) odds are they'll need to check a few things out just to determine the problem.
Old Feb 3, 2009 | 06:20 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
dealers don't repair LCDs. they just order a new cluster and install it. while they do that you can ask them to give you the 2009 cluster which has those hooded rings if you want. (personally not a fan of those hooded ones)
Old Feb 3, 2009 | 06:48 PM
DAnton1316's Avatar
Really? How many times did it happen and how long has it been since? Did the exact same things disapear?
-Dan
Old Feb 4, 2009 | 11:20 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
It really couldn't be too many different things. They can use SDS to do an LCD screen test to determine if it is displaying all of the data that is being sent to it (it looks like it is since there are no irregular bars, etc., in the image) and see if there are any fault codes. Looks like there is a fault in the CAN bus sending data to the I/C, or the I/C itself is bad. The I/C will store fault codes if there is an issue with CAN communication.
Old Feb 4, 2009 | 12:34 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Can you select different menus with the command wheel when this happens? This is a strange one a definite job for the dealer.
Old Feb 4, 2009 | 03:49 PM
delirium's Avatar
C350
when i had it, i could do everything as usual except the "PRND" was missing from the display.
Old Feb 4, 2009 | 05:08 PM
Pristine's Avatar
2014 E350 4Matic
If the display starts to go bad, they basically have to replace the whole instrument cluster. That's what happened with my 00 S500 when things started to disappear.
Let them figure out what needs to be done and ask them to give you a loaner while they work on your car.
Old Jul 15, 2010 | 06:33 PM
BAPHA's Avatar
W204 2008 C350
Unfortunately, I am going to have to dust this old thread off...I started experiencing the same problem (intermittently) with the instrument cluster display as the OP and was wondering what was the resolution for him? Did the dealer have to replace the entire cluster ?
Old Jul 15, 2010 | 08:13 PM
BlackjackM's Avatar
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
When my transmission was acting up, the display started acting weird although didn't disappear completely. It looked like his first pic even when driving, no "C" or "S" for comfort/sport and no gear highlighted. They ultimately replaced my transmission valve body because it also has a control unit attached, but my trans was also acting up.
Old Jul 16, 2010 | 03:06 AM
aowhaus's Avatar
2008 C300 Sport 4matic
maybe you could ask to upgrade to the newer style hooded guages.
Old Jul 16, 2010 | 04:25 AM
Sathinas's Avatar
S65
It's a little more complicated than that...
The TCU talks to the ECU which in turn talks to a bunch of other modules as well as the Instrument Cluster module. Basically, there is no direct link between the transmission control unit and the cluster. It's a... cluster, if you know what I mean.
Old Jul 16, 2010 | 06:29 PM
BAPHA's Avatar
W204 2008 C350
...and of course, today the display works like new! I expected this, actually, so that's why I am posting here, since there isn't much a dealer can do if I cannot show them the problem.
But in general, do you think the issue could possibly be in the connectors that go into the display, rather than the actual display itself?
Old Jul 16, 2010 | 07:50 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Loaner car
- Dan
Was there any question??
Phil Smart will provide a loaner but Barrier will not.
Old Jul 17, 2010 | 02:21 PM
BlackjackM's Avatar
Take a video or pic when it is acting up. A good dealer will take that as proof and start looking.
