very very small issue... :\
Old Feb 9, 2009 | 11:03 AM
TB5...'s Avatar
2009 C300 4Matic
but annoying to me none the less...
is there anyway to change the inferior tall *** plastic locks ?
i can't understand why they make everything so luxurious then skimp on the locks...
if there was a thread bout this... my bad... i did look.
Old Feb 9, 2009 | 11:42 AM
norb's Avatar
2009 C63 AMG
ebay has a few options.
Old Feb 9, 2009 | 11:45 AM
TB5...'s Avatar
2009 C300 4Matic
i was wondering what the un/installation process would be like...
removing panels?
unscrewing?
imma check e-bay now... good looks
Old Feb 9, 2009 | 12:45 PM
BerBer63's Avatar
2009 C63
Do a search, dozens of threads.
To get you started, I did mine yesterday. This is just for the front locks, the rear door pins are different and require disassembly.
- Grab a towel and set of pliers
- Throw the towel over the door pin, grab door pin with pliers and rotate it left until loose, the front door pins are attached via threads like a screw
- Its on pretty tough, I replaced them with CF ones on ebay
Old Feb 9, 2009 | 01:04 PM
TB5...'s Avatar
2009 C300 4Matic
aite they are called 'door pins' i was searching for 'door locks'...
couldn't find them on ebay or this site...
imma search for door pins now tho... i assumed others would find them ugly tho.
thanks.
Old Feb 9, 2009 | 02:31 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
you can use W203 door pins for the fronts, but rears, as mentioned, are a different beast all together. To my knowledge, only Brabus has different pins specifically for 204 rear and fronts.
Old Feb 11, 2009 | 08:53 AM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Front Unlocked
Front Locked
Back Unlocked
Back Locked
Back locked with reference. That is as close to fluch as I can get the backs at this time.
Old Feb 11, 2009 | 09:11 AM
TB5...'s Avatar
2009 C300 4Matic
Originally Posted by Ron Jr
Front Unlocked
Front Locked
Back Unlocked
Back Locked
that looks proper man... i definitely don't mind that the back ones are not flush... once the front ones are i'm happy.
so the fronts unscrewed and screwed in... and how did u end up puttin in tha backs? dealership?
Old Feb 11, 2009 | 10:34 AM
Ron Jr's Avatar
Lots of cutting and drilling. A quick search of door pins will give you all of the info needed.
