Optimal Gear Range
I tried it today while the car was moving at 50mph and I definitely noticed a huge improvement in throttle responsiveness; granted the engine suddenly revved up from 2000 to 5000 to allow this.
So can someone shed some more details regarding this feature? Am I supposed to do this while at a stop or while in movement? And do I constantly have to do it at different speeds or does it automatically adapt?
Or, you could just use S and press on the pedal harder...the car will downshift.
If I'm going 50mph and I activate the "optimal gear range" function, it seems to usually rev up to 4-5k at D3, and the throttle becomes way more sensitive. Without activating the option, at 50mph it is usually doing around 2k, and the throttle will lag a bit if you want a quick speed increase.
Optimal gear is basically just lowest possible gear mode, nothing more. That is why the RPM is higher.
