Comand: Memory Card "Lost Songs" ----> Solution for problem!
Old Mar 1, 2009 | 08:29 PM
c350driver's Avatar
C 350
Did anyone have this problem yet:
Initially I loaded about 16 Gb of music on my Flashcard (its a 32 Gb) and it worked fine! Now last time I added some music to on of the 4 main folders I have, and when I inserted it in the system they wouldnt show up!
I tried it again in my PC, and they were on there. On another PC, same story. Then I changed the names of some of the folders, and it appeared to be working again. But now I added some music today, and no music to be found again. But this time renaming the main folders isn't helping anymore.
It looks like a problem that a simple F5 push in windows would solve, but that button is nowere to be found in our cars ofcourse....
Anyone?!
Old Mar 1, 2009 | 09:19 PM
theinmoe's Avatar
C350
I have same problem, no solution yet with 32GB compact flash card. Reformat, reload files did find more new folders but not all. Only shows 22 folders at root. Something to do with Windows CE not refrashing the directory I guess.
Old Mar 1, 2009 | 09:21 PM
c350driver's Avatar
C 350
Solution
Ok Guys,
well after walking up and down to my car and PC a few times I figures it out!
If this happens to you, just make a new folders and name it whatever you want. Drag all the files out of the old folder in there, then delete the old folder. Rename the new folder to the old folder (or something else, doesnt matter). Et voila!
What happens is that you now actually edit the drives reg-files. Now Comand sees it as a new file, and really checks it for new content.
Still, its weird it doesnt do this automaticly.
Old Mar 1, 2009 | 11:17 PM
theinmoe's Avatar
C350
What about root folder, cant see after 22 folders. May be I orignally had 22 folders and when I add more it shows first 22 folders in alphabetical order. How to change or find drive reg files?
Old Mar 2, 2009 | 02:06 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Hmmmm. I have noticed a similar issue with missing songs/folders, but I've always been able to correct it by removing the memory card and reinserting it.
On an unrelated note, I've noticed that songs (and maybe folders?) that start with a number don't show up correctly.
Old Mar 2, 2009 | 03:51 PM
lug's Avatar
lug
C320 CDI 4matic Brabus D6(III), Black.(SOLD). Current - EQE 350 W295
I also have a 32Gb compact flash card with similar problems. Nevetheless I can see far more that 22 folders on my root... What do you mean by reg files?
I will try re-inserting. I do not seem to have a problem with songs beginning with a number (actually most of my songs start with a number) my problems is with whole folders not showing up, and none of them start with a number.
I am begining to think that COMAND will only see 16Gb and not the full 32Gb. Thinking about it COMAND has a 255 folder limit and 4000 file limit so I wouldn't be surprised if there is a 16Gb limit as well.
One thing that I have noticed is that if you try to transfer MP3s to the HDD ALL the folders are displayed (even the missing ones) but if you choose one that is not normally displayed it will not copy anything and just seems to get stuck.
