HID question adn help
Old Mar 13, 2009 | 06:16 PM
tehc300's Avatar
C300
So I just bought a HID kit From DDM Tuning. I bought it in 55w because that was what was referred to me to disable the warning since a 35w kit would trigger the warning.
My problem is the lights work fine while the engine is off and I get no warning but when I start the engine and accelerate a little the HIDs both shut off. Once they shut off I get the bulb error out warning. My guess is since the 55w kit requires more power would that be the cause?
I'm thinking of exchanging for a 35w kit with the error code eliminator.
Has anyone had any problems similar to mine?
Or if you've bought HID's with no problems from a seller could you please refer me to where you got it from and what type of kit, 55w or 35w with code eliminator?
Thanks!
Old Mar 13, 2009 | 06:22 PM
spoolIT85's Avatar
C300 sport 4matic
You also needed to purchase the warning code eliminator...
http://www.ddmtuning.com/products/Wa...ir-130-94.html
Post some pictures of what the light output looks like after the install (ie. against a wall to see the light pattern of an after market H7 hid kit + stock halogen projectors)
Old Mar 13, 2009 | 06:31 PM
tehc300's Avatar
C300
The thing is I don't think that would help. I have the 55w kit now which doesn't require the warning eliminator and I just got off the phone with the guys at DDM and they told me both kits run at 6amps.
So I'm assuming I'm not getting enough power on startup while the car is running. I was told maybe running a relay harness (Direct power from the battery) would help in this situation or upping the fuse for the headlights by 5.
Old Mar 13, 2009 | 06:36 PM
spoolIT85's Avatar
C300 sport 4matic
^^ there are a few guys with the 55w kit that didn't need the error cancellers... but a greater number had to get the warning code eliminator to get it to work right! same symptoms that you were experiencing...
mercedes & chryler both have super sensitive temperaments when installing aftermarket hids.
Old Mar 13, 2009 | 07:27 PM
Savage c-300's Avatar
C300 Sport, MM, P1
i have the EXACT same kit. you need the cancellors. once you install them they will work just fine.
Old Mar 13, 2009 | 07:36 PM
alexyanglaw's Avatar
2008 C300 Sports, AMG 18 inch wheels, MM package, 6000K HID Kit, 20% 3M tinted all around
I agree, I have same kit, you need to get the cancellor.
Old Mar 13, 2009 | 07:40 PM
tehc300's Avatar
C300
You guys all have them in 55w?
I just tried to run a relay as well and no luck. Bulbs will turn on and turn off within a second. I don't wanna order the canceler and have the same issue. Its weird though as 55w is the standard on mercedes. My old kit was a 55w kit and it worked fine till about 4 months later it just stopped working.
I have the worst luck with HIDs
Old Mar 15, 2009 | 02:49 AM
hellasmania219's Avatar
2009 C300, 2012 GLK350, 2012 C350C
i have the 55W DDM kit and i needed the error cancelers as well. post a pic of light pattern cast as i am curious to your outcome also...
Old Mar 17, 2009 | 07:54 PM
tehc300's Avatar
C300
just ordered the cancelers hopefully the problem gets fixed.
Thanks everyone for the help. I'll get some pictures up when they're installed.
