Mercedes Bluetooth and Blackberry
Subscribe
Apr 2, 2009 | 10:50 AM
Quote: Does anyone knows how to stop the blackberry from ringing when there is an incoming call, and only let the MB command ring to inform you??
My blackberry is always on "Virbrate". so it does not ring when there is an incoming call. Of course, there are other options on the Blackberry that you can try such as "Quiet", etc.
Reply 0
Apr 2, 2009 | 01:01 PM
It should take over automatically when in carkit mode
Reply 0
Apr 8, 2009 | 02:51 AM
transfer the address book from the Blackberry to the COMMAND system.
I have a Mercedes Class B and a blackberry 8707. I would like to transfer the address book from the Blackberry to the car system. Using the hereafter procedure the address book is not transferred. The answer from the car system is "0 adress received". The phone works correctly with the bletooth. Tks in advance for your help.
Maurice from TOULOUSE France.
Quote: I have a Blackberry 8800 and it works fine. Here's how to transfer the address book from the Blackberry to the COMMAND system.
The following instructions are to be done on the Blackberry, when it is connected to the COMMAND system:-
(1) Click on the Set Up Bluetooth icon.
(2) Select MB Bluetooth
(3) Select Transfer Address Book.
The phone numbers are then transferred from the Blackberry to the car system.
To update the phone numbers in the future, first delete the data base on the COMMAND system, and then reload the phone numbers using the 3 steps outlined above.
Reply 0
Apr 8, 2009 | 11:36 AM
I would suggest you to update blackberry OS/Software and then try.
Reply 0
Apr 8, 2009 | 11:38 AM
Quote: I have a Mercedes Class B and a blackberry 8707. I would like to transfer the address book from the Blackberry to the car system. Using the hereafter procedure the address book is not transferred. The answer from the car system is "0 adress received". The phone works correctly with the bletooth. Tks in advance for your help.
As far as I know your phone does not have the capability to transfer contacts to your car. But if you have all your contacts info saved in your sim card then you can swap phones with anyone who has a compatible phone transfer your contacts.... swap phones again. here is the link for compatible phones and steps to transfer contacts
http://www4.mercedes-benz.com/manual...on/index.shtml
Reply 0
Apr 9, 2009 | 05:29 AM
Quote: As far as I know your phone does not have the capability to transfer contacts to your car. But if you have all your contacts info saved in your sim card then you can swap phones with anyone who has a compatible phone transfer your contacts.... swap phones again. here is the link for compatible phones and steps to transfer contacts
Thank you very much for your help. I will try to swap phone with my contacts transferred to my sim card.
Tks again
MOMO31
Reply 0
Apr 9, 2009 | 06:05 AM
  #32
Quote: i have a problem sending my phone book i have a bb 8100 can someone help please...
May be you have too many phone entries. Try to limit it by using categories.
-DW
Reply 0
Apr 15, 2009 | 03:21 AM
  #33
Solved! Thanks...
Quote: You might get an error of "object push server" while sending contacts from the above mentioned procedure. The only thing you have to do is to disconnect your phone(hands free service) and then send the contacts. You must connect back the hands free service after you finished sending the contacts.
There is another way to enable push server mode and that is by going to blue tooth Options. From update list of services, change hands free unit to object push. Transfer your contacts and revert the object push to hands free unit.
Hope it helps.
This was my problem: i solved thanks to your help!
Reply 0
Explore
Apr 21, 2009 | 01:00 AM
  #34
Terrible Bluetooth connection
I have tried both a Palm Centro and a Sanyo Katana with Sprint over my Bluetooth. People claim that I have a severe echo with both phone and that my conversation is impossible to understand. Is this a known problem or do I likely have a defective console?
Reply 0
Apr 22, 2009 | 09:24 PM
  #35
I just picked up my new GLK today. Very excited. The dealer synced my blackberry 8310, but I am struggling to sync my wife's blackberry 8703. I am a techical misfit. Any detailed instructions would be tremendously appreciated.
Reply 0
Apr 19, 2010 | 12:26 AM
  #36
Anyone know how to delete the data base for the addressbook?
Reply 0
Apr 19, 2010 | 11:26 AM
  #37
Quote: Anyone know how to delete the data base for the addressbook?
It's a menu option in the Phone section. I believe it's called "Delete External Data" or something very similar to that. Press the TEL button, go to the left to whatever the option on the far left is called, select that, and I think Delete External Data is in there. That's the general idea, anyway, and I apologize if it's not 100% correct but I'm not in my car right now to verify it.
Reply 0
Apr 19, 2010 | 12:57 PM
  #38
Quote: It's a menu option in the Phone section. I believe it's called "Delete External Data" or something very similar to that. Press the TEL button, go to the left to whatever the option on the far left is called, select that, and I think Delete External Data is in there. That's the general idea, anyway, and I apologize if it's not 100% correct but I'm not in my car right now to verify it.
Yeah my Phone menus and screens look nothing like what is described in the Command Manual. Think I'm visiting the dealer today.
Reply 0
Apr 21, 2010 | 08:10 PM
  #39
Hope it helps.
I was getting the "object push server" error with my 2009 C350 and BB Bold 9000 but then all I had to do was select the "Receive vCard" button on the MB screen before selecting to transfer phone book on the BB blue tooth screen and it transferred over 300 phone contacts in less than 30 seconds.
Reply 0
May 26, 2010 | 10:24 PM
  #40
Hey i have a blackberry storm 9530 and i have Tried the things you guys have explained above an i cannot get my phonebook to sync no how if someone could help me that would be so great i don't really understand the post by hazee any help would be awesome!!
Reply 0
Jun 11, 2010 | 10:12 PM
  #41
I just did the sync but it only transferred something like 400 contacts. I have 2,000! Is there a limit?
Reply 0
Aug 13, 2010 | 01:19 PM
  #42
2008 350/THE NEW BB TORCH SMARTPHONE
Sounds like the same old problem.....bought the new Blackberry Torch yesterday. Can pair the BB with the MB350 but can not transfer my contacts from the phone to the car. Keep getting the "unable to locate object push server". Any ideas? Any help would be greatly appreciated.
Reply 0
Aug 13, 2010 | 01:41 PM
  #43
2008 350/BLACKBERRY TORCH
Quote: I was getting the "object push server" error with my 2009 C350 and BB Bold 9000 but then all I had to do was select the "Receive vCard" button on the MB screen before selecting to transfer phone book on the BB blue tooth screen and it transferred over 300 phone contacts in less than 30 seconds.
Thank you so much for your suggestion "Bretr", selecting the "receive vcard" worked and my contacts transferred in seconds.
Reply 0
Feb 20, 2011 | 12:45 PM
  #44
Hope it helps.
How do I do this : The only thing you have to do is to disconnect your phone(hands free service)
Reply 0
Subscribe
Currently Active Users (1)
