Rotor Replacement for 2007 C230
Old Apr 7, 2009 | 09:26 AM
regularbob's Avatar
2007 C230 Sport
I am planning on this myself as I have done it before on my 2003 C230 as well. Are there any changes that I need to be aware of? I havent taken of my wheels yet and would like to know what I am getting into. It looks like I have to remove the front 4 reverse torx bolts on the caliper housing, but I never had to do that before...
Old Apr 7, 2009 | 10:52 AM
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
For the the pads and rotors you will need a T30 to remove the screw holding the rotors on, a T45 or 8allen(dont remember which) and a 18mm socket, also calipers presses, and a bungie cord to hang the caliper. I also recommend a large hammer to remove the rotor as they are usually rusted on pretty good. To tell if you have SBC the hydraulic unit under the hood with all of the brake lines going out of it will say SBC on it if you have SBC also it will have an accumilator on the bottom of the pump. If you do not have SBC then this unit will only say ESP and will not have an accumilator.
This is for W203 but I haven't really noticed a big difference between my friend's W203 and the W204. Going for grooved discs when the cracking in these perforated discs continues
Old Apr 7, 2009 | 10:55 AM
regularbob's Avatar
2007 C230 Sport
Thanks... So I will not need to remove the bolts on the front and back of the caliper housing right?....Just the 2 Hex bolts in the back....
Old Apr 7, 2009 | 11:00 AM
ctgilles's Avatar
Read some more here: http://www.edmunds.com/ownership/how...7/article.html
It's a pretty straightforward job. Logical thinking will get you far. Just the 2 rear ones get the calipers off. And for the love of God, block the rear wheels and use axle/jack stands and not just a hydaulic one!
-EDIT-
Here's a very interesting post: https://mbworld.org/forums/2994922-post3.html
with pics!!
