"Sport" Button
Old Apr 9, 2009 | 10:25 PM
len56's Avatar
C350
"Sport" Button
I'm talking about the sport button that is supposed to change your suspension settings...does it work well? Like, is there a noticeable difference?
Old Apr 10, 2009 | 01:25 AM
duboisi's Avatar
w204 c230
I think you are talking about the Advance Agility Package. And yes it has a very noticeable difference. In "S" mode, most of the time RPM is maintained above 2000rpm, kickdown is faster, steering is 10% more direct. As for suspension, my personal feel is that, in "C" mode it is very much softer and comfortable for family ride, in "S" mode, it is like the standard Avantgarde (which i think is the Sport in US) suspension setting.
Old Apr 10, 2009 | 03:27 AM
white_glass_top's Avatar
2008 C300 SPORT (white)
i never noticed a change in the suspension???? i see a difference in the engines performance, as far as higher rpms and changing of the gears. unfortunately, i do not think drivers in the states, actually notice a difference b cuz of speed limits. but on the autobahn i really can get it in, lol.
Old Apr 10, 2009 | 03:47 AM
duboisi's Avatar
w204 c230
Are we talking about Advanced Agility Package with this button?
http://www.flickr.com/photos/21176250@N03/3428635684/
Old Apr 10, 2009 | 04:00 AM
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
I have it but never use it. Regular chassis is already bumpy enough round these parts Stiffens up the damping, but also gets the gearbox into S and I wish it didn't do that. So I never use it
lx Raven xl's Avatar
C180K 2011 COMAND, AMG, Dynamic Xenon, Business Pack, H&K Audio and +
Advanace agility package does change the suspension. It makes it much stiffer and also the gear change ratio is affected. The kick down and upshifts are faster. Considerbly less lag when upshifting and down shiffting.
The "sports" button is placed in the dash console under the memory card slot.
Old Apr 10, 2009 | 07:32 AM
Norm01's Avatar
2011 E550 Coupe
I have a question, I have a 2009 C300 4Matic sport model automatic and it does not have that button below the memory card. It does however have it beside the shifter, was the button moved on 09's. I know it's supposed to adjust the shift points, not sure if it also affects suspension.
Old Apr 10, 2009 | 08:16 AM
duboisi's Avatar
w204 c230
If you have the "S/C/M" button (W204 with steering paddle shift) or "S/C" button (W204 without paddle shift), near to the gear shifter, then you don't have the Advanced Agility Package. Without AAP, only shift poinst are altered and not suspension setting.
As mentioned, for W204 with AAP, the "S/C" button is below PCMCIA card slot. W204 with AAP plus paddle shift, the bottom button next to shifter is marked with "M" for activating manual shifting using the paddle shift.
Old Apr 10, 2009 | 11:06 AM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
AAP is not available in the US.
Old Apr 10, 2009 | 12:54 PM
len56's Avatar
C350
yup!
Old Apr 10, 2009 | 12:56 PM
len56's Avatar
C350
great! sounds like its not just a gimmick!
we get it here in Canada with the sport package...
we have smooth roads around here, so it'll be good for when i want to let some anger out
Old Apr 10, 2009 | 03:02 PM
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
Post Yes
As others have said about Advanced Agility Control or Active Control...
Yes, if I drive on smooth road in C, I can feel the ripples in road when S-Mode was activated. It feels it is faster when I activated when stopped, but I maybe wrong, as apposed to on the go.
You can keep the softness of C-Mode, by using the paddles or gearshift.
It will go to M-Mode without stiffening the suspension. read up about using M-Mode and getting out of it again.
I find driving the B170 in M-mode works much better when many uphills and downhill roads in front of you. I can anticipate the hill better than full automatic.At most I go down two gears, sometimes 3 to maintain speed and not going over 4000RPM, flat rode I just go out of M, or keep it 7th at 2000RPM, no strong headwind. With the C350 I rarely use it, just the right paddle to make sure its running in 7th, not 6th.
The manual says to use C-Mode for autobann driving.
Old Apr 10, 2009 | 03:30 PM
who8888's Avatar
15 E350 4Matic
As they say: "C" is for comfort and "S" is for sport. Always on "S" with my ride except the first 1k miles.
Old Apr 10, 2009 | 06:48 PM
Glyn M Ruck's Avatar
Super Moderator
The Advanced Agility Control is fantastic.
Some on this thread are confusing it with the standard autobox profile control.
Old Apr 10, 2009 | 06:58 PM
len56's Avatar
C350
Thanks for the detail!
So, I'm driving in C, and if i press the Sport button, it puts the car into S. I can then put it into M by hitting the paddles, or the C>S>M button by the stick, and the Sport Suspension will stay on? (just wondering if I got it right)
And if I'm driving in C, then I hit the paddles or the C>S>M button with the Sport button OFF, the suspension will stay smooth? (also wondering if I got that right)
thanks!
Old Apr 10, 2009 | 09:17 PM
acr2001's Avatar
2012 C300 4Matic
thanks!
I believe you are correct. But just to reiterate this is ONLY true on cars with the advanced agility control. US C classes DO NOT have this option.
Old Apr 11, 2009 | 01:47 AM
berkut_g's Avatar
W204 C320CDI
all the info you need
all C - Class come with agility control. Advance agility is that "sport button" in the dash next to the parktronic.
AGILITY CONTROL
Code:
AGILITY CONTROL suspension with selective damping system
The AGILITY CONTROL suspension with selective damping system, specified as standard, raises the bar for
ride comfort in this segment:
 Combination of selective and passive damping system
 Integral valve which reduces the damping force automatically in the event of weaker shocks
 The system works like normal shock absorbers in the event of stronger shocks
 In the event of heavier impacts, the level of damping provided by the system increases significantly,
which, in turn, helps to stabilise the entire vehicle
AGILITY CONTROL - How does it do it
Code:
Operation.
The AGILITY CONTROL suspension combines the advantages of a selective damping system with those of a passive damping system. The conventional comfort-oriented spring/damper system is augmented by a stroke-dependent damping system (standard equipment).
The function module in this selective damping system consists of an elastomer piston which offers the oil flow a bypass in addition to the conventional damper arrangement in the event of weaker shocks. This reduces the level of damping in the range between +/- 10 mm and significantly reduces road roar and tyre vibration as well as substantially improving the chassis' tyre/road contact characteristics without compromising on active safety. In the event of heavier impacts on the chassis, the selective damping function activates the full damping effect.
ADVANCED AGILITY
Code:
Enhanced driving pleasure at the push of a button: ADVANCED AGILITY package with special sports mode (optional extra) While the suspension adjusts to the road in the standard-fit AGILITY CONTROL, the new  ADVANCED AGILITY package with special sports mode (optional extra) can also respond to the driver's mood.
At the push of a button the driver can vary the vehicle characteristics between a comfortable and sporty set-up. The following parameters can be influenced:
 Continuously variable damping
 Speed-sensitive power steering with
variable centring and more direct steering
ratio
 ESP?/ASR (traction)
 Accelerator response
 Speed of automatic gear changes
Old Apr 11, 2009 | 06:57 AM
ctgilles's Avatar
Just too bad I have to put the gearbox in M, the shifting on this 5 spd auto box is not good. Why oh why no 7G on the 220 CDIs???
thanks!
Not quite. In COMFORT SUSPENSION, you can only choose between C or M shifting. In SPORT (AAC), you can choose S or M. So no C shifting in SPORT (AAC) and no S shifting in COMFORT SUSPENSION.
That's why I don't like it that much... I like a firm ride and with AAC on a smooth road: WHOA! But I thought it just controlled the shocks, I still want C-driving with S-suspension!
Old Apr 11, 2009 | 11:31 AM
len56's Avatar
C350
This is ridiculously complicated xD
What if I'm just driving along in C, sport OFF , and I hit the C>S>M button.
Will it turn the sport suspension on, or skip to M? (because it should only switch to S, if it follows the order on the button :P)
Old Apr 11, 2009 | 02:20 PM
acr2001's Avatar
2012 C300 4Matic
This is more of a gimmick than anything else. I'm not saying it doesn't help with the suspension, but it isn't something you can control, and it is something that most modern cars do, just in different ways. Don't take that the wrong way though. What you said is true.
Old Apr 11, 2009 | 06:37 PM
Super Moderator
Agility control is a passive system.
Advanced agility control is an active system & works a lot better. The dampers are actively controlled
Advanced Agility control gives you the sport selection on the dash AND your normal gearbox profiling to a degree.
I have the W204 design DVD in my possession - wish I could post it.
Old Apr 11, 2009 | 07:21 PM
len56's Avatar
C350
How'd you get the DVD???
Old Apr 11, 2009 | 09:50 PM
Super Moderator
Benz handed them out to the motoring press & good customers in South Africa. Very good production if you want to fully understand everything that went into the W204 after they let their customers endurance test the W203. It also covers every available option in detail & how they work. It runs for hours - even has a full accessory catalogue - every wheel option available globally etc.
Old Apr 12, 2009 | 12:12 AM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
How true
[QUOTE) ...big snip...they let their customers endurance test the W203. [/QUOTE]
I don't think you realize how true this was.
Buyers of early W203s WERE MBs test drivers since it was clear that damned little testing was done before releasing the cars to the buyers. It's not a exaggeration to say that my '01 C320 was in the MB shop 8-9 times annually for warranty repairs for the entire 7.5 years I drove it. And this was the norm.
Which makes my C300 a Mercedes miracle with almost NO problems in the 1.5 years I've owned it. I still can't believe it.
Old Apr 12, 2009 | 05:56 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
another garbage decision from MBUSA not to offer this in US. just like they're not offering individual options anymore.
