I Still Cant Figure Out the Locking System
2017 E300
I guess i can put more effort into finding the answer for myself, but ive noticed a few observations regarding the automatic unlocking after engine shut off
Sometmes, after turning off the engine, I open my driver's side door and all four doors unlock right there. Sometimes, i open my door and only my door unlocks. i thought this had to do with the weight sensor on the passenger seat but i cant find a pattern.
anyone know why/when one of the other happens?
all the doors unlock, once I turn off the engine and open the drivers side door, the power to the interior shuts down as well, and the MM screen closes
each and every time, has never done anything different
Edit - I don't have a key, I have the keyless go, so when I stop, put it in park, push the button in the dash, this turns the car off, but the MM will stay on, until I open the door, it will then shut off and close, and all the doors unlock.
I have it so that when I push the button on the remote, it unlocks all the doors
2017 E300
yes, only my drivers door unlocks after the first push.
maybe i wasnt clear though. i am referring to actually being in the car, after driving, turning off the engine. once i open my driver side door, (that is pull the lever), sometimes only my door unlocks, and sometimes all the doors unlock
2009 C350
Nothing happens when I turn off the engine, the MM screen closes when I pull the keys out (not when the door opens), and all the doors unlock when i open the drivers door.
MBworld Guru
white and whiter
if the key is in the ignition and not to the off position only the driver door will unlock. all door will unlock when the key is out of the ignition or when in the off position.
edit: just tried it for you. all doors only unlock when key is out of ignition. when key is in the ignition even at off position it only unlocks the driver door when you pull the handle.
