C350 Dynoed
Old Apr 30, 2009 | 12:30 PM
Bokx_350's Avatar
C350
C350 Dynoed
Hey guys, So I decided I'm going to dyno my C350. I got an appointment for tomorrow at 1. This is the place whee I'm going to do it:
DSG - DENT Sport Garage - Self Built. A sport garage in Norwood, MA. USA
Apperently they have a Dyno Dynamics dyno (not that I know anything about dynos). So my question is, what whp should I expect from my automatic c350?? What would be a good transmission loss estimate to convert the number I get to crank hp??
Old Apr 30, 2009 | 12:38 PM
2tonOfun's Avatar
C350 and a Lightning.
Be sure to put it in "dyno mode" (see threads here on how to) and I bet you see about 240ish to the wheels.
Looking forward to your results.
Old Apr 30, 2009 | 12:46 PM
Bokx_350's Avatar
C350
Yep, already saw the youtube video on this. The tunner at the dyno shop told me that an auto tranny lost could be as much as 25% . In that case it would be more like 205 whp (not cool).
Old Apr 30, 2009 | 01:01 PM
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
15% loss is my guess. So about 230-235whp.
Is there a dyno mode??? How kewl!
Old Apr 30, 2009 | 02:36 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Awesome!
Do you mind if I ask what they are charging you? I've found a couple places around here for $75-100 for three pulls but they are dynojet dyno's and I've been told they are one of the least expensive/accurate dynos on the market?
Old Apr 30, 2009 | 03:08 PM
Bokx_350's Avatar
C350
Their flat rate is $100 for 3 pulls.
Old Apr 30, 2009 | 04:18 PM
palladiumw204's Avatar
C350 4matic coupe
15% loss is for a manual transmission...20-25% is typical for automatics
Old Apr 30, 2009 | 04:58 PM
Bokx_350's Avatar
C350
Any specific numbers for our cars?
Old Apr 30, 2009 | 06:36 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
18% loss on MB automatic is pretty much the norm. some where between 220-230rwhp depending on the dyno.
if you all really want to know what the car puts down without the variance of what wheels/tires you are running find a shop with dynapack. It'll be a more accurate 16-17% loss without factor in the wheels.
Old Apr 30, 2009 | 09:13 PM
2tonOfun's Avatar
That's what I would guess, once the tranny reaches a 1 to 1 ratio (not sure what gear that is on the MB tranny).
Old Apr 30, 2009 | 09:22 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
3rd gear on the 5spd
should be 3rd or 4th on the 7spd. probably the 3rd since the 6th and 7th are just overdrive.
Old Apr 30, 2009 | 09:51 PM
BerBer63's Avatar
2009 C63
5th gear is closest to 1:1 and 18% loss is the standard.
Dynos are at their best when measuring gains/differences from baseline, but it will do.
Old May 1, 2009 | 04:40 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the 5th gear on the 7spd is closest to 1:1? wtf... I always thought the 1:1 ratio is used in the middle in most cases. edit: searched around and you are right. hmm....
Old May 1, 2009 | 05:16 AM
jagass's Avatar
pick up
Some said that the place is good...I hope it's true...
Old May 1, 2009 | 08:42 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
The car is rated at 268 at the crank.....how can you expect to see "240ish" ? I'll say 205.....211 tops.
Old May 1, 2009 | 10:04 AM
Bokx_350's Avatar
C350
I agree that is over optimistic. At 18% lost, which appears to be a good estimate, I should get around 220 (268 x 0.82).
Old May 1, 2009 | 10:32 AM
Krytech's Avatar
240 would certainly be too high for a stock engine, but with your tune you might be close to 235-240 to the wheels if the MKB #'s are close?
Old May 1, 2009 | 01:23 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
18% for MB Autos on Dynojet (they read too high).
22% for MB Autos on Dyno Dyanmics (most realistic real world #s).
Old May 1, 2009 | 03:43 PM
Bokx_350's Avatar
C350
OK, I got the results. Again, this whole thing is new to me, and I just found out that HP is not so defined as consumers (me included) think. It really depends on a lot of things, especially the tranny loss and the dyno used.
Anyways, he did 3 pulls at both 4th and 5th gear; the results were very consistent with the 5th gear being 2 whp lower than 4th gear. The Max whp was 228. I was a little disappointed at first, but the tunner was kind of impressed.
He told me that Dyno Dynamics is a very realistic dyno that actually adds force to the wheels, and that on a Dyno Jet my numbers would have been around 10% higher. He said that as a comparasion, a manual E46 M3 is rated at 333hp and they have dynoed it at 270 - 275 whp, and that the difference from a manual to an automatic is always significant. When I asked to estimate how much power I had on the engine out of his experience he said at least 300HP considering the automatic transmision; this is close to what MKB advertises for their tune.
So the only way to know how much more power i'm getting is to get a stock C350 and dyno it on the same shop. I am left with this number wich doesn't really tells me much. I mean, I could be optimistic and say that 228 +10% = 251 on a Dyno Jet /tranny loss of 18% = 306HP. Or I could be more realistic and say that 228 / 22% tranny lost = 292HP (as suggested by AMS Performance). As the worst case scennario I can take the 228 whp / 18% tranny loss = 278HP
At the end of the day there is no definite answer. I'll post the graphs later when I get a chance to scan them.
Old May 1, 2009 | 04:57 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
which tune are you running?
Old May 1, 2009 | 05:10 PM
Bokx_350's Avatar
C350
MKB's ECU Tune https://mbworld.org/forums/c-class-w...ming-up-d.html
Old May 1, 2009 | 05:13 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by Bokx_350
i see. MKB does make good tunes for MB.
Old May 1, 2009 | 05:27 PM
Bokx_350's Avatar
C350
The tunner told me that the fule mixture was very lean at full throttle. He suggested that I compare this number to what MKB is supposed to deliver, but I'm not going to bother since I'm satisfied with the results anyways.
Old May 1, 2009 | 05:29 PM
BerBer63's Avatar
2009 C63
That's why dynos are at their best when testing differences...otherwise their are to many variables to ever know - 4th vs 5th, Temperature, Octane rating, Fan Setup, 18s vs 19s, +/- the variability of the dyno itself,etc. etc.
Congrats now you have a baseline for you're next mod
Old May 1, 2009 | 05:37 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
your AFR went from near 15 to dipping 13 at full throttle. I would be scared a little. only if you have the stock AFR to compare. wonder if that AFR is on the edge. I rather have them run a little richer and sacrefice a little power.
that's a board torque band tho
