C350 Dynoed
Regarding Air fuels, Did he go full throttle from the beginning or only 4200rpm+? 4200+ rpm the graph looks totally fine, and is roughly around ~13.1 which is totally fine. The 15+ though is concerning but again tough to say.
Also, Go back to your dyno shop and have them print you out a new graph which a much lower Y-axis scale so you can actually see whats going on, the scale is too high so you can't really see any definition on the chart, they look almost horizontal. The max you need on y-axis is 300-350 tops, 500 is overkill to say the least.
hope that helps.
Too bad the op didn't dyno before his "tune".
With that said, most software claims are exaggerated because HP sells, the more they claim the more they sell. The best thing to do is go by actual dyno results on a loading dyno to see how they actually perform with both before & after dyno done on the exact same dyno in similar conditions. On most MB NA applications 10-15HP is about all you will get max (if that, except for a few exceptions where the stock ECU was detuned such as C63 & etc).
http://www.dyno.com.au/dyno/controll...ow2WD450DSPage
Specifically ths part:
Power Analogue bar & digit: kW (HP) [0.1 kW (0.1 HP) resolution]
Having the resolution they claim is great for on the fly tuning but from run to run if its repeatability / accuracy is not specified (which it isn't) then absolute measurements are debatable and subject to significant variance.
Therefore as chubbs032 has posted above (and others elsewhere) back to back runs may vary significantly - can be as much as 10-30HP.
As another data point multi million dollar engine dyno's used in F1 only achieve an accuracy of 5% at best - thats a dyno right on the crank removing all question of transmission loss in an air conditioned test chamber.
I'm not saying DD isn't a good dyno - it's probably one of the best out there, imho just don't try and use it for something it wasn't designed for. There's a big difference in meaning between resolution and absolute accuracy.
I'll say 205.....211 tops.
