C220 chiptuning
Old May 10, 2009 | 03:08 PM
whn's Avatar
whn
E92 335i
C220 chiptuning
Does anyone know how much we can get power out of C220?
Brabus D3 S kit will boost power up to 220hp / 470Nm.
But I think it's over priced since I can have "normal" chiptuning less half that money what brabus would cost and power is around 210hp / 480Nm.
How much will 210hp / 480Nm effect 0-100 km/h time compared to stock C220?
Old May 11, 2009 | 03:52 AM
whn's Avatar
whn
E92 335i
bumb anyone?
Old May 11, 2009 | 11:32 AM
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
Topspeed 241 km/h
Consumption city 8.64 / 100 km ( -0.46 / 100 km) Consumption freeway 4.84 / 100 km (-0.26 / 100 km) Combined 6.27 / 100 km (-0.33 / 100 km)
216ps/480nm
Old May 12, 2009 | 08:10 AM
whn's Avatar
whn
E92 335i
Originally Posted by ctgilles
Topspeed 241 km/h
216ps/480nm
Where did you get yours chiptuned?
Old May 12, 2009 | 12:34 PM
dslotboom's Avatar
2008 C220 CDI Estate Avantgarde
C220 Chiptuning
I did mine at Ziptuning in the Netherlands. They claim that after chiptuning the engine has following specs: 216 hp (170 hp), 480Nm (400Nm)torque. From 0-100 km/hour takes 7.6 sec instead of 8.5 sec with standard engine. Topspeed (did not test myself) should now be 241 km/hour instead of 229 km/hour. I did not do a Dyno, but I can notice the difference in practice. With the same driving style as before the engine is more economical -8% diesel and has much more power in accelation (max torque is now available at 1850 instead of 2000 rpm) and the accelaration from 80-120 km/hour has very much improved.
Regards,
Dennis
Old May 13, 2009 | 03:45 AM
ctgilles's Avatar
Yeah Ziptuning in Belgium/Holland is currently offering the best numbers. Dyno is available at extra cost. They have a May special 100€ off so that's 499€ total Plus they take over your MB's warranty!
Kempower has a better rep but only offers around 190ps with dyno included but for 800€ excl VAT (+21%). Kempower is VERY reliable and has a lot of customers in Scandinavia and the rest of Europe.
We also have Heinz in Belgium but have heard horror stories about sensors being shut down and turbos breaking down.
Old May 13, 2009 | 06:01 AM
whn's Avatar
whn
E92 335i
Do you think that Ziptuning could send the modded software to here in Finland and my local chiptuning shop could install it? Because in Finland best numbers for C220 are 195hp / 480Nm and price is same 599€
Old May 13, 2009 | 06:05 AM
whn's Avatar
whn
E92 335i
I was just thinking that is it possible to put X-pipe for our C220's if I put brabus exhaust?
Old May 13, 2009 | 06:50 AM
Petje's Avatar
W205 C400
X-pipe? You have a 4 cylinder, so there's no X-pipe
If you order the Brabus you get the 2 silencers (left + right) and the connection pipe (Y-pipe) to your oem exhaust.
Fittment is perfect and they deliver everything in the box.... i have them on my C180K
Old May 13, 2009 | 08:31 AM
whn's Avatar
whn
E92 335i
yep, but I was thinking that if I put it after The Y-pipe and then add X-pipe and then connect brabus silencers
Would that make engine sound better or am I crazy?
Old May 13, 2009 | 02:09 PM
ctgilles's Avatar
A tractor is not something to be proud of LOL. Diesel sounds awful.
Maybe you can send your ECU? Contact them on info@ziptuning.nl
Old May 13, 2009 | 02:41 PM
dslotboom's Avatar
C220 Chiptuning
I do not think they will send the software, because they programm directly into your ECU. There is no ECU replacement. Secondly they take over MB warranty so I guess they want to do everything themselves. Their nearest office for you would be Groningen, it would be a nice drive back with your tuned engine. BTW, first 500 km you have to be carefull.
Regards,
Dennis
Old May 14, 2009 | 01:33 AM
whn's Avatar
whn
E92 335i
Where is ECU located in our cars? is it hard to take off by myself or do I need to go local chiptuning shop to take it off?
Old May 14, 2009 | 01:45 AM
Diesel Benz's Avatar
Topspeed 241 km/h
216ps/480nm
Is the the gearing or why not higher top speed? The standard C320CDI does 250.
Old May 14, 2009 | 01:53 AM
Which C220 is your car actually? On a 204.002 at least the ECU is located at the engine bay on the right side (passenger side), forward from the firewall.
Old May 14, 2009 | 03:20 AM
ctgilles's Avatar
5 speed ZF gearboxes on the 220 CDI. Go figure why... I don't get it Hell, on a bad day you can hit a gearbox wall at 200kmh. Had it on different 220 CDI's: flooring and not getting past 200kmh it's like it was limited I'm sooo unhappy with this 5 speed transmission
Old May 15, 2009 | 03:06 AM
Petje's Avatar
W205 C400
Yes you are
No but thats not an option, dont know what the sound will be on a Diesel... i think it will sound good....
Old May 15, 2009 | 03:22 AM
Petje's Avatar
W205 C400
If you go to a local shop you dont have to take it off, they will re-program your ecu by the OBD port.
Or you can get an plug and play box http://www.diesel-power.com/
Contact Steen@kleemannuk.com , he sells the dieselpower products, and he have it on his C220CDI.
Standard 110 kW 150 hp 280 Nm 206 lb-ft
Diesel Power 128 kW 175 hp 327 Nm 241 lb-ft
Old May 15, 2009 | 12:13 PM
whn's Avatar
whn
E92 335i
Could someone please contact to ziptuning.nl for me? I've sent emails but did'nt get any answer
Old May 16, 2009 | 09:46 AM
Petje's Avatar
W205 C400
What do you wanna know from them?? I will call them for you if i know what you want!!
Old May 17, 2009 | 05:36 AM
ctgilles's Avatar
They normally reply when they have the time, don't worry.
I think he wants to know whether he can send in his ECU?
Old May 17, 2009 | 07:16 AM
whn's Avatar
whn
E92 335i
I want to know could I send my ECU to them to get it re-programmed or can they send the software to the local chiptuning shop to get it re-programmed ecu by the OBD port.
Old May 25, 2009 | 03:29 PM
whn's Avatar
whn
E92 335i
bumb anyone please ask for me
