Noisy Cracking Sound in Steering Rack Area
2007 W204 220CDI Classic Sedan
I have one metalic crack sound in my steering rack area near the end of either lock extremity.
Has anyone else experienced this ? I would be grateful to know of the outcome when visiting the dealer?.
I have done no modifications. I have not noticed this noise before taking a trip on a pot holed road. The car has done 15,000 km.I have removed the wheels & inspected the area & have not found anything obviously damaged. I hope you are correct in saying it is normal for the shocks to make this noise.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Noise
It's a known defect and it's covered by the warranty.
I believe he's talking about the strut bearings and bushings - I had strut bearings replaced on the right side (warranty) and some bushings replaced on both sides on TSB
I took the car to the dealer to check the oil weep & mentioned the stones & steering noise. They retensioned the seal housing & pressure fitting on rack under warrantry but charged me 1.7 hours for removing gravel between rack & chassis. ( A$125/ hr.) After " consultation" with head office customer assistance, thankfully the charge was waived!
I am grateful that there was no suspension /steering bush problems but am now aware that I will have to drop the sump guard when a steering noise re-appears after travelling on gravel roads.
Super Moderator
If you ever hear any more noises - hope you don't - Check the sway bushes & links. Also check the rack bolts for tightness.
