How do I remove and paint my rear exhaust diffusor?
Old May 17, 2009 | 04:42 PM
Robbio204's Avatar
C350
If anyone can help that would be great
Old May 17, 2009 | 05:47 PM
VaderSS's Avatar
'06 E55, W204 C350, '04 Carrera C4S, '02 ML55 (Wife's)
You can see this link
https://mbworld.org/forums/c-class-w...tall-pics.html
Well…. It’s a difficult one if your trying to paint the stock diffuser… because its not flat but textured. In addition, you need a bonding primer before paint and clear. It will also more than likely chip easy.
As far as removing it, that’s the easy part. Two 10mm bolts in the middle and two screws on the ends. Then using a flat bladed screwdriver carefully push out the tabs (top of diffuser to bumper from inside/under rear…
Hope this helps!
Old May 17, 2009 | 09:06 PM
TheDarkSide's Avatar
C300 4MATIC (w204)
The clips are a bit of a pain in the ***. Make sure to have someone around with small hands to help unclip them.
Old May 18, 2009 | 04:20 PM
Derspeed's Avatar
X3 and 2012 C coming soon
It can be painted. It has been done plenty of times. On my last car, the entire bottom of the front and rear bumpers and doors were textured black plastic and I had it all color-mathced. If you go to a good body shop, they will know how to prep and paint it. Since it is not on the front of the car, it should not chip if it is prepped and painted correctly. You can even have the body shop sand the texture off and make it smooth. Since that area does not flex that much, the paint will not need a flexing agent added to it.
Old May 18, 2009 | 06:30 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
I just grabbed and pulled.
