cleaning the NAV screen
Old May 18, 2009 | 08:50 PM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
Im having the worst luck cleaning the nav screen,
there are streaks that are very visible when hit with direct sunlight and i am unable to clean it!
I've tried
water
eye glass cleaner
LCD cleaner
with microfibre and paper towl and no luck!!!!
any suggestions?
Old May 18, 2009 | 10:34 PM
kevinwithdabenz's Avatar
08 c350
i just just windex and a bounty paper towel and mine comes out fine no streaks.
angeloxnet's Avatar
i didnt try windex, afraid due to the alcohol content but at this point im willing to try it
Old May 18, 2009 | 10:56 PM
08 c350
i had the car since may of 08. and i been using that since and never had any problems. and idk this might sound weird but i use mistolin on the leather lol and still comes out good
Old May 19, 2009 | 06:27 PM
CrAZyVeGAsBoY's Avatar
C300 4matic Sport, CBR 954
i wouldnt go with windex, never know what the amonia might do, i mean should be safe but i just use a microfiber towel and water, does the trick every time and gives me peace of mind, but up to u just my .02 cents.
Old May 21, 2009 | 01:02 AM
SoCal208's Avatar
12E350, 12ML350, 08C350
On W211 section, someone use Windex to clean the NAVI screen causing some permanent scratch on the screen (screen had to be replace). I used water with the microfiber towel. It's squeaky clean (I had "display clean" solution (no amonia or alcohol) to clean my flat screen TV & computer monitor but water is the best, when using the microfber towel).
Old May 21, 2009 | 01:36 AM
SoCalC55's Avatar
2019 AMG C43
Microfiber + Water for sure
works on mine very well
Old May 21, 2009 | 02:02 AM
jagass's Avatar
pick up
You better try the windex...
Old May 21, 2009 | 03:02 AM
micropower99's Avatar
2008 Mercedes C300 4Matic
Buy a good LCD screen cleaner with microfiber cloth. That's what I use and it works like a charm.
Old May 21, 2009 | 05:31 AM
Fergie's Avatar
C230 (W204)
Microfiber + Eye grasses cleaner
Old May 21, 2009 | 05:35 PM
i dont see how windex can cause a scratch, it sounds more like the towel they used scratched it.
Old May 21, 2009 | 05:45 PM
ulovemybenzo's Avatar
99 W210 E55
Old May 21, 2009 | 09:28 PM
08 c350
i been using the windex since i got my car which is almost a year now so yeahhh no scratchs or nothing i dont get how a Liquid could cause a scratch but okayy
Old May 22, 2009 | 04:05 AM
yes but windex is bad due to the ammonia in it which is a chemical that will dye ur tinted window if used for long periods of time.
Old May 22, 2009 | 08:21 AM
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
+2
Old May 22, 2009 | 10:47 AM
JimPap's Avatar
2008 C300 Sport, RWD, US
Sound like the OP got something on the screen that won't come off with just water. Could be from the factory or when the dealer got possession.
I'd go with windex and after its clean, use plain water to get any remaining ammonia off.
Old May 22, 2009 | 05:33 PM
akuma84's Avatar
'08 C350 Sport
I use Meguiar's Quik Detailer Interior and it works wonders. I even use it on the MB-tex.
An alternative solution if you want to use Windex is getting the "green" bottle of Windex specifically made without ammonia intended for automobiles. I think I got mine from Wal-Mart.
And always use a microfiber cloth.
