Hill Assist Issues...
Recently, I have experienced intermittent instances where the car's brakes hold it in place (you can tell the feature is activated because the pedal is rock hard and the vehicle doesn't creep when you let off the brakes) even when I'm on level ground. Anyone else? It makes take-off herky jerky and I don't like it.
I have experienced the hill assist on inclines upwards of 20-degrees. You know its working because you let go of the brake pedal and the car stays in place (whereas other cars would start rolling backwards).
I have never had an instance where the brake pedal has become rock hard though. The hill assist is an electronic system and doesn't affect the pedal position afaik ... unlike some cruise control systems where the gas pedal would be held down.
Perhaps something to check with the dealership?
If your on a hill and stop, and then release the brake pedal, and before the car's hill assist feature release's you hit the brake pedal again, it will become rock hard as mentioned, I don't think it's a flaw, but since the system is "under pressure" trying to push more brake fluid is not possible, and the rock hard feelings occurs....
Well I at least think this is why......
GK
GK
mine has never done this.....
very odd indeed....
My wife's BMW has this issue. It doesn't catch everytme, but when it does it is quite annoying. The only reason I haven't taken it in is because I don't really drive it that often.
Good Luck,
Paolo
