DIY_Led_Eyelids[TB5]
Old Nov 24, 2013 | 03:42 PM
  #126
codeblue5007's Avatar
2008 Mercedes Benz C300 4matic Sport
Thanks TB5 for the great pics. I took on the eyebrow replacement with AZNoptics LEDs and have a few observations from a rank beginner. First, removing the trim pieces held by those plastic fasteners only requires pulling up the plastic center post with your fingernails or a thin screwdriver blade. I pried the first two thinking they were all one piece and broke part of the plastic screw. Short and long needle nose pliers are needed to grab the sockets. If you leave the eyebrow lights on while doing all this it's possible that the lights will go out and you have reboot the system by locking the car and starting all over again. Not sure what the exact sequence is, but to my surprise the lights do come on. Another thing. The LEDs are very delicate. The top of one broke off as I was trying to insert it in the socket holder. So I have 3 LEDs now and one normal one. The LED must maneuvered so that it fits through the cilindrical holder. Can't just push it in there and hope for the best. That's why it's useful to have them on. Lastly, I found it impossible to fit the drivers side led without loosening the windshield wiper reservoir. Thanks to all in this thread.
Old Nov 24, 2013 | 05:57 PM
  #127
carmbu's Avatar
1998 CL600, 1998 C230 2010 C350
I came across a video on someone showing the procedure on how to replace the LED eyebrow bulbs on a W204 C350. Hope this helps.
Old Nov 24, 2013 | 06:20 PM
  #128
Thanks. I like his suggestion to keep an assortment of light bulbs for the vehicle on hand.
Old Nov 25, 2013 | 01:12 PM
  #129
VD2108's Avatar
2011 C300 4MATIC
TB5 thank you for well documented DIY. I changed mine a couple of weeks ago. This DIY was very helpful and useful. Well done!
Best,
-VD
Old Dec 7, 2013 | 09:08 PM
  #130
||||||||||'s Avatar
2009 Mercedes C350
Maybe someone in here can help..I just ordered some W5W Canbus LED's for my eyelids on my C350. The seller personally has a C series and has used them in his with no issues (even has pics on his ad).
My LED's flicker and either stay on when the lights are off, or will flicker off and on even when power is cut. They won't stay on constant even when driving around town. I've tried these LED's on the interior, license plate and trunk, and they work fine everywhere but on parking lights.
Any ideas? I don't believe it to be the bulbs.
Old May 31, 2014 | 01:15 AM
  #131
timlouie415's Avatar
2010 e350
Sorry to bring an old thread back, but i installed some LEDs and now they flicker.
I got the leds from v-leds.com.
Old May 31, 2014 | 02:16 AM
  #132
aamirani's Avatar
2011 C300 4MATIC
Bad LEDs. Use AznOptics. Vendor on here, great products and customer service.
Old May 31, 2014 | 02:22 AM
  #133
builthatch's Avatar
C63
x1000000000000
best customer service.
Old May 31, 2014 | 02:27 AM
  #134
Project C's Avatar
MB C250
^ + 1
Super cool dude
been using Azn led for more than 2 years now and his magic Morimoto
Old Aug 22, 2014 | 07:24 PM
  #135
SupremeChicago's Avatar
w212
Just ordered 2 pairs of 5k LEDs going to install this weekend, cant wait
Old Jan 19, 2015 | 08:05 PM
  #136
BenzAMX's Avatar
2011 C300 4Matic
This thread is worthless since no images there. I m not able to see.
Old May 25, 2015 | 04:42 PM
  #137
Leckraj's Avatar
Mercedes w202 c200, Mercedes W204 C180
Hello guys,
i Just installed Can bus LED on my w204,
The right side working but the left side none of them are working, error message is send on the dash.Can anyone help me.
Regards
Leckraj
Old May 25, 2015 | 05:08 PM
  #138
sagar526's Avatar
2010 C350
Originally Posted by Leckraj
Hello guys,
Regards
Leckraj
Did you try flipping the led bulb around?
Old Aug 11, 2015 | 01:14 AM
  #139
Jaro87's Avatar
C300
Well I did everything the diy stated, however I might pulled too hard on one of my lightbulb that part of the wiring is out of the connector and on the other side the led isn't working regardless of turning it... **sigh** last resort is take it to the dealer ship and have it all replaced smh
Old Aug 11, 2015 | 01:21 AM
  #140
It should be an easy fix at a stereo shop. If the LEDs aren't working after turning off the ignition, reinserting the key, then the LEDs are probably no good. I'd go back to the spade 5w bulbs and forget the LEDs
Old Dec 16, 2015 | 10:05 AM
  #141
fl0wmastr's Avatar
c250 Coupe Sport
pics don't load! please fix!
Old Mar 24, 2016 | 04:52 PM
  #142
dennish's Avatar
1992 MB 190E, 2016 MB C300
I just completed this job on my car. The yellow plastic bulb housings were very tightly lodged. For what's it worth, I suggest using flat(broad) nose needle nose pliers. I could not get enough purchase with pointed needle nose and they slipped off. Also, it helps to wiggle the yellow bulb carrier before trying to pull out. The outside driver's side was a royal PITA. But patience and wiggling led to success. I was careful not to pull on the wires. I know some say to pull on the wires, but they are fine wires and I didn't want to chance pulling one out.
Old Apr 21, 2016 | 05:34 PM
  #143
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
pics update plz?
Old Oct 24, 2025 | 11:38 AM
  #144
AngusAranda's Avatar
2011 W204 C300
There's no pictures in the 1st post.........
