Service Specials & Coupons Thread!
#51
Lexus IS 350 F Sport
#52
For Bay Area people. Park Avenue Motors in Palo Alto, CA has Service A for $99.
http://www.parkavenuemotors.com/inde...pecial=service
#53
C300 Sport/Palladium Silver on Black/P2
I went for B Service, but did my dust filter myself beforehand.
I go to the same dealer all the time, so since I did dust filter, only charged service A price and the brake fluid change I wanted.
So I got service Service B and Brake Fluid Change for approx $310. I thought that was pretty good.
#54
Here's a couple of specials from Silver Star Motors in LIC, Queens, NY - coupons print on their website and there are other coupons too.
Flexible Service System - A-Service
Change your vehicle's engine oil and filter
Rotate tires if applicable
Ensure the warning and indicator lamps, horn, windshield/headlamp wiper and washer systems, and seat belts are functioning correctly
Inspect tires and check tire pressure (including spare)
Inspect brake pad thickness and disc condition
Check and correct all fluid levels
Reset your vehicle's FSS counter *Model year 1998 through 2006 vehicles are equipped with the Flexible Service System (FFS)
$219.95
Flexible Service System - B-Service
Replace the dust filter in all SLK, CLK, C-Class and E-Class models, and in S-Class and SL-Class models without the active charcoal filter, prices may vary by model.
Inspect windshield wiper inserts
Inspect and rotate tires
Lubricate and inspect throttle linkage
Ensure the parking brake, steering play, headlamps and exterior lamps, warning and indicator lamps, horn, windshield/headlamp wiper and washer systems, seat belts, and backrest lock (S-Class only) are functioning correctly
Inspect brake pad thickness and disk condition
Inspect front axle ball joints and Poly-V-belt
Reset your vehicle's FSS counter *Model year 1998 through 2006 vehicles are equipped with the Flexible Service System (FSS)
From $395.95
Wiper blades additional
$219.95
From $395.95
#57
Service A for $123, B for $299 from Berberian Mercedes of Stockton
#59
"A" service for $129.95, "B" for $229.95
#60
2008 c300 [] 1969 Chevelle SS [] 2010 Camaro
Service B in Dallas
Service B is right around the corner (800 miles)... I just called around and got three prices:
Stealership #1 $499 and pointed out that this was only the BASE PRICE
Stealership #2 $475
3rd party service facility: $331
Of course, none of the above are offering any specials, will probably go for the $331 service but can't help feeling that they're doing something less then the dealerships.... So two questions:
Are the small service shops that specialize in MB, BMW, and Audi really doing everything the dealerships do for a much cheaper price?
AND
Has anyone found ANY coupons for the Dallas/Fort Worth area???
Stealership #2 $475
AND
#61
2013 C63 AMG
Service B is comin up for me as well (1,000 miles) so now I have to start my search for prices for this. Im seeing the average paid and it looks like its around the $300-375 price range. Im in Arizona so if anyone has any coupons or specials coming to them they would be appreciated!
#62
Stealership #2 $475
AND
Stealership #2 $475
AND
#64
#65
1 Post
2008 C300 Sport, 2010 RX350 AWD
Here is another link for the best available coupons I can find for Nothern California..
http://www.montereymercedes.com/ou/m...page=s_coupons
Service B for $299, brake fuild for $88..going to do m service b and brake fuild this month..hopefully my dealer will accept the coupon from the competition..
#66
https://mbworld.org/forums/3880915-post1.html
#67
A:$99 B:$229 Oil Change:$45-60 Brakes:$199
http://mboffresno.com/Specials-Service.aspx
A Service: $99
B Service: $229
Till 1/31/10
http://www.autobahnmotors.com/specials/service.htm
Oil Change: +10 for synthetic
$34.95 - 4 cyl
$39.95 - 6 cyl
$44.95 - 8 cyl
$49.95 - 12 cyl
Brakes: $199.88
Replacement of Genuine Mercedes-Benz front or rear disc brake pads.
A Service: $99
B Service: $229
Till 1/31/10
$34.95 - 4 cyl
$39.95 - 6 cyl
$44.95 - 8 cyl
$49.95 - 12 cyl
Brakes: $199.88
#68
09' E350 AMG Sport, 09' C300, 03' Honda S2K
I love this thread, it should updated on a montly base. I personally think that if people would know that MB does give out specials for services, it would help them lean towards MB more, but too bad you have to be an MB owner to know, lolz. it even cheaper than Hondas, considering it every year or 10k miles for oil changes.
#69
Just use the ones that was quoted up there for $99. Print it out, bring it to the dealer and they should honor it. If not go some where else and they'll honor it.
#72
A few different ones
My Service 'A' isn't due till May but it is good to be prepared.
