COMAND retrofit
I bought a Euro COMAND unit and screen, along with a universal GPS antenna. I will be updating the COMAND unit to work in the US (based on past threads). My question is what additional parts are *actually* needed. I am going to try to get whatever I need ordered tomorrow...
From what I can gather below is a breakdown of parts.
Must have
A2045405706 Screen wiring harness
A0018207675 GPS Antenna - Can do aftermarket for a fraction of the cost
A1234750120 Pad for GPS antenna x3
A2045409706 APS wiring harness -?? Can this be reused from the audio20?
A2118200088 Antenna adapter cable- Again.. can we reuse this from the Audio20??
Debatable (based on heat, life, etc)
A2119840429 Bolt for fan x2
A2048321245 Air duct
A2048320645 Air duct
A2048320545 Air duct
A2048321045 Air duct
A2048300508 Axial fan
Optional
A2048702851 Central air nozzle screen switch
A20483041549116 (black) Central air nozzle
Other
A0225457426 Clutch for antenna cable - the dealer can not find this part...
(it's within the first few pages of w204 forum, just use the search feature and all the questions you will ever had can be answered in that thread)
I wouldnt consider the screen buttons optional as you would want to fold down the screen when driving in dark conditions etc.
The antenna clutch is needed as it will connect the two separate FAKRA connectors (BT and GPS) into one dual connector.
Do not know if it is possible to fit two single FAKRA.s next to eachother.
