Navigation screen won't pop up when I press "ON" button.. any idea?
2008 Black C300 Sport 4Matic
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
As of this morning, the navigation screen won't pop up. It was working fine yesterday. This means the radio, navi, phone, etc. doesn't work. Before I take to my dealership, does anybody know why this happened and how you can fix it w/o taking in for service? Thanks guys
1 Post
2013 C300 Sport Black Darth V3.0
There is a fuse to pull in the trunks panel I want to say 7 but I could be wrong. Do a forum search it has been mentioned in the past.
Seems I was wrong must be getting old. Here's a thread I found that might help.
https://mbworld.org/forums/c-class-w...uses-w204.html
1 Post
'08 C350, '05 Mazda 3 HB, '07 330i
that's weird... take it to the dealer and avoid doing something they can use as an excuse for failure... Keep us UpdatED!, this can happen to anyone... hope you can fix it soon!
I can fool around with the fuse box but figured I'd just drop it by the dealership to have them take a look... I'll keep ypu updated later today when I find out what had happened... very bizarre and unusual.
Audi A4 1.9 TDI 2002, MB C200 CDI 2004, MB C220 CDI 2009
I had same issue.
Programmed to go to dealer.Had a second tough.
I did open the fuses/relays door in the trunk (right side) and pushing a little on the fuses and tapping on the relays solved my problem.
Hope works for you too.
My car has been at the dealership for a full day now and they still haven't officially diagnosed the problem. I'm really hoping that this does not have anything to do with the VIM that I installed over 1 year ago. Does anybody know anything about the VIM causing this problem and if its fixable? Thanks
'10 C300
this happens to me pretty often... it happens almost 100% of the time when I shut the engine down while the screen is coming down. if i do that, the screen wont open up at all. i fix the issue by resetting fuse #20? i believe... anybody know of a permanent fix?
