Above and beyond 160 MPH
Old Sep 18, 2009 | 05:44 AM
Peabody's Avatar
Question Above and beyond 160 MPH
The engine modification I'm looking at getting is supposed to increase my top speed to over 170 mph. Looking at my speedo, I'm seeing that it only goes to 160. Will I damage the analogue dial by taking it over that? The digital readout will still be accurate I'm assuming.
Old Sep 18, 2009 | 06:48 AM
albert101's Avatar
W204 C280
you might mess up the gears for the analog dial since it runs on a gear. you might mis-align it and your speedo will be off. The digital in theory should still work. Though if you plan to go at speeds past 170mph, I highly suggest you modify your suspension and brakes. Or better yet, get a C63 AMG.
Old Sep 18, 2009 | 11:41 AM
Peabody's Avatar
I'm looking at new brakes already.. In retrospect I probably should have got the AMG, considering how much cash I'm dumping into mods.. oh well, it's my first Mercedes. Next one will be AMG. The suspension shouldn't be as much of a problem here as it is in the states as German roads are far nicer than US highways. According to Kleemann, the M272 can have the vmax set wherever you want it, so I'll just set to 160 MPH instead of risking screwing up the dial, replacing the dash seems too much cost and fuss.
Old Sep 18, 2009 | 02:21 PM
mat2hu's Avatar
C350
MAKE SURE YOU HAVE PERFORMANCE TIRES!!! Make sure your tires speed rating could handle the speed you wanna go up to.
Old Sep 19, 2009 | 12:32 AM
mirage15's Avatar
c300 4matic
+1. At 160 or 170 I would also start worrying about aerodynamics a lot. Having a 170mph C300 plane would suck for the split second that it lasted.
Old Sep 19, 2009 | 03:46 AM
Peabody's Avatar
Agreed, though I think the worst case scenario will be lowering if I actually plan on driving 160 MPH as a habit.. I think the fuel economy on the C350 would suck too bad for this. The dealership gave me a CLS55 to drive for a week when my customs paperwork got tied up and my delivery was late, and the most lasting memory I have of driving it was going through almost 3 tanks of gas.
The stock tires are rated to 186 MPH.
Old Nov 1, 2009 | 06:29 AM
Peabody's Avatar
Thumbs up
Well, here's what it looks like on the speedo.. I'll post a video to YouTube later.
Old Nov 1, 2009 | 06:32 AM
Peabody's Avatar
Carlsson told me that the digital AND analogue dials would stop at 160, and 258kmh is 160.3MPH. I hit a speed limited area as I was hitting 160 so I will try again later and see if I can get the digital up to 260, which would be 161, but they told me only my tachometer would rise after 160 that not even the digital would go up.
PRO TIP: Cruise control maxes at 130 MPH. Jerks.
The video is a bit shaky at first, but here it is.
Old Nov 1, 2009 | 12:35 PM
mirage15's Avatar
c300 4matic
Video taping and taking pics at 160 in a C300... Been nice knowing you man...
Old Nov 1, 2009 | 03:30 PM
Peabody's Avatar
I just set the camera on top of the steering wheel, no need to be so dramatic, especially when the road was completely empty.. plus it's not a 300.
Old Nov 1, 2009 | 03:36 PM
Peabody's Avatar
It was mentioned before so I will say the aerodynamics and feel of the car is amazing. It holds rock steady.
Old Nov 1, 2009 | 04:43 PM
JimPap's Avatar
2008 C300 Sport, RWD, US
Did you get the sense that the car was more stable above 100 than say at 70?
Are you on "H" rated tires?
Old Nov 1, 2009 | 05:00 PM
acr2001's Avatar
2012 C300 4Matic
Seriously? Not on a modern car. That 'analog' dial is running purely off of a digital signal. It just stops at the max point, no damage will result.
Old Nov 2, 2009 | 03:02 PM
Peabody's Avatar
I'm running Michelin pilot sport plus, they are ZY rated (186+ MPH).
I've never noticed performance issues until ~125MPH, and that is some moderate rear shimmying during hard braking. As far as stable aerodynamics the car seems flawless at every speed. Your only enemy will be the road you're driving on.
Old Nov 2, 2009 | 04:54 PM
Sincity's Avatar
I was going to ask why do you need to go 160 and then I see you live in Germany. Like you said, you should have gotten a C63, tune it, and call it a day.
