SMERC Engineering upper strut brace
Our front unibody chassis is quite stiff from the factory from what I understand. I noticed that the driver side strut tower has a factory brace tying it in with the firewall, but, the passenger side doesn't have such brace. This brace just ties everything together. Subjectively speaking, it does seem to make steering a bit more responsive when I was doing a slalom manuever on the street. However, I only had the vehicle for 1200 miles since new and haven't driven it too aggresively to further evaluate.
Installation is a simple DIY and shouldn't take you more than 15 minutes.
As far as weight, spec, pricing, and availibility, you will need to contact forum member TheDarkSide from SMERC Engineering. He did tell me that SMERC is in the process of being a forum sponsor and will be introducing the first batch to the forum soon. This brace is not C63 specific and will also fit the C300 and C350.
The following pics are not from the photoshoot but are my own using a P&S camera.
Thanks Everyone!
It would be awesome if you guys produce more w204 stuff! I know you guys are planning an X pipe but I'd like to see that expanded to a full affordable quad/dual exhaust system.
Do any of the strut tower brace suppliers do impact analysis (madymo or other simulation program)? This has a potential greater effect than changing the color of side marker lights!
Most strut bars are round wall and some are double rounds to counteract flexing during loading. Others attach at the shock towers and mid point on the firewall areas.
Just my thoughts...
Disclaimer: I am not speaking on behalf of SMERC, but merely relaying my many years of experience on collision damage. Also, I am not an engineer/specialist in the field of impact analysis or occupant safety for vehicles.
Imagine a 90 degree impact where the bullet vehicle strikes the passenger side of a C Class with a strut brace stiffer than the MB design intent for cross car crush. Imagine the right headlamp area of the bullet vehicle lines up approximately with the brace. If the area is now stiffer than OE design intent, as the bullet vehicle strikes, and begins to rotate clockwise (more than it would if the brace area were not overly stiff) such that the left headlamp area penetrates the right passenger door, that load may now be higher than it would have been and provide a greater challenge for the side impact protection MB provides.
Another issue is that if the vehicle is just stiffer and doesn't suffer any deflected load into the passenger cell, the stiffness in a side impact may result in higher lateral g forces on occupants, possibly exacerbating internal injury.
Just a speculative, hypothetical example. But, before possibly changing crush behavior, I would like someone to study this more.
Doesn't the CLK BS have a strut tower brace from the factory? And the regular CLKs do not?
I know, I wish we could draw. I'm not good at describing myself.
