VHT Nightshades
Old Oct 14, 2009 | 01:55 PM
killacam7479's Avatar
2009 C300 Sport 4Matic, 1999 Jeep Grand Cherokee Laredo
VHT Nightshades
Anyone have experience tinting tail lights with VHT Nightshades?
http://cgi.ebay.com/ebaymotors/VHT-N...item19b6fad974
I found a place to tint my tail lights in Chicago, a body shop (Gold Coast), but they said I'd have to supply the paint. I came across this stuff on eBay. I don't want it pitch black, more of a dark cherry look. Also, I want it glossy. Any input is appreciated. I also saw a spray from Japan, not sure if it's really the same thing or not.
Old Oct 14, 2009 | 05:58 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I looked at the same product. It looked like it would Black-out the tailight-not tint it. The body shop you brought your car should be able to provide the paint. Most shops just spray a gray which has been thinned out.
Old Oct 15, 2009 | 12:33 AM
scoonie089's Avatar
09' C300 4matic
i can give you a friends number if you pm me take a look at my car he did an amazing job and clear coated them after too... he can do any shade you want.
https://mbworld.org/forums/c-class-w...tter-pics.html
Old Oct 15, 2009 | 01:17 PM
Hey Sigfreak, thanks for the advice. This place I talked to said the paint they have would make the brake light not visable. I've been wanting to do this for quite some time. There is an autoart by my parents house but they said it would be $400, and the jon's tinted tails would require me to mail them to him, which sounds like more trouble than it's worth since I can't drive without them. So I thought this would be the best solution. I found another type online, not sure if this will be the same issue of being a "blackout" rather than tint, because I do want a little bit of red in it (not pitch black).
http://cgi.ebay.com/ebaymotors/JDM-S...item5883c9ddba
Old Oct 17, 2009 | 10:14 AM
E350 Sport/ML350RWD
Yes. That looks right. It says it for the "smoked" look. As long as it doesn't say "blackout" you should be ok. I saw a spray advertised that said it was semi-permanent. It would stay on through washing and weather but could be removed with rubbing alcohol if needed. I'll see if I can find that again.
