Reset
I would like to change my oil at 10 000 km and not at 20 000 km which is when the first service is scheduled, looking at the computer reading.
Will the computer reset itself if I change the oil or will it merely keep on counting down.
Is there any way that Mercedes will be able to tell that I changed the oil.
I am going to use an OEM filter and Mobil 1.
I keep a written record of oil changes and just reset the system every other change. It doesn't matter.
I have been using the suction method for about ten years, using a Top Sider which is a marine store item, costing around $60. You can see it at www.westmarine.com. This one uses a tube inserted in the dipstick tube. Since you are not in the US, you might have to look around a bit.
There are others.
The trans fluid change interval is now about 40K miles.
