Sport Mode
depends on where u live if u notice the difference. but it does, it allows for gear changing at higher RPMS, and if u live in the states, u will not notice, b cuz by the time u can do an actual gear change, ur already pass the posted speed limit.
+1
this and S holding the rev in lower gear at certain points e.g. hill, are the only differences i know of. then again, what else would you want?
- though kickdown works much better with the paddleshift. never noticed much of difference in kickdown between C and S.
Now if you are looking for suspension response, in addition to the gear control, then you would need the Airmatic suspension, which places you into a different beast.
Also by driving in C mode would I save on gas or is this negligible.
If it's the latter, then absolutely it makes a difference in ride and handling, steering weight, as well as throttle response.
If it's the C or S button by the gearshift, then it's just changing the rev range for the transmission shifts (it shifts earlier), and allows the car to be started off in 2nd gear. C or Comfort mode used to be known as Winter mode because it was supposed to be used only in slippery conditions to limit how much wheelspin you would get. More torque = more wheelspin. And if you start off in a higher gear, there is less chance of wheel slippage.
